Any news about the UT X48 T2R version?Has anyone got it?
the oficial page,has having problems, i trying to download bios, from official page, but appears corrupt info or a lot of letters and numbers.
The Digital PWM gets pretty hot although my Q6600 is running @ stock speeds + volts. I already replaced the factory compound with AS Ceramique. Any options of a fitting PWM/Mosfet block for the LT-X48 or will Eddy make one for us.... :D
hey anyone using that bernstein card? i gave it a few weeks , playing with settings/drivers and hopeing it would get better , but my god , it has to be the worse sounding card ive ever heard lol its terrible. voice is so low and no bass . very tinny sound .
i tried a few realtec drivers and the sound is bad with all of them. must be the card.
im looking at getting one of these -Creative Sound Blaster X-Fi XtremeGamer Fatal1ty Pro but im worried it wont fit. the pci slots are so damn close to gpu. itll be really squashy.
Yes we are waiting to get the German Watercool soon, if you interested put your name on the list:
http://www.xtremesystems.org/forums/...d.php?t=182949
don't worry, fits very well, i must put in the slot two, my gfx card, because dont fit my pcie x1 tv card if i put in slot 1 my gfx card.
Look my sistems
EJTREM3
Hi m8 i have the same nb cooler as you but on your pick it looks like you have the nut all the way down to the black plastic spacer. Is this so as i have a good 1.5mm space between mine on both side`s ??
Thank You :up:Quote:
Originally Posted by Jor3lBR
My concern is that I live in Singapore, pls advice :(
Do u guys recommend to replace the stock TIM of the PWM, with for example MX-2?, or it isnt worth the hassle
I would recommend changing it.... :yepp:
I dont know where I had read but some1 said u have to be carefull doing it since those chips are pretty sensitive, they arent the paste they used on isnt that sticky right?
Mine on the other hand was soft and moist and had good contact before I got rid of it by using earbuds.... :p:
My board is Rev A01.... :up:
I had 4x 2gb DDR2 1000 OCZ Platinium, is a good ram to do 450~500FSB on this motherboard ??
I've noticed that my board overvolts everything, so I've had to set the CPU VTT voltage a bit differently than mentioned at http://www.clunk.org.uk/forums/12434-post9.html
However, the GTL settings do seem to be correct, once you get the CPU VTT voltage exactly the same as the "real" voltages mentioned at the page.
I'm now running 8x450 (3600MHz) with 1.328vcore , CPU VTT 1.310v, NB 1.510v. If I find these settings to be primestable, I'll post them here for ya :)
someone can tell me the distance beetween the two holes of the NB please ?
http://www.exoid.com/wp-content/uplo...3/img_1136.JPG
i need the distance beetwen holes we see on this HS ..
