Originally Posted by
Talonman
Thanks guy's!!
Leak test is under way. No issues so far. :up:
I have both the D-Tek and the EK NB hooked up to the Keg.
My Pro mount kit should arrive soon from Petras. I do realize that I will have to leak test again, after taking the D-Tek apart, and installing the Pro mount kit.
NB backplate modification stage is engageing now to accommodate for the larger mounting hardware.
One thing I find interesting. As some micro bubbles leave the D-Tek block, they are evenly dispersed in the water. They enter the EK block, and apon exiting, a neet tornato shaped swirling is very apparent. The pattern extended about 2 to 3 feet in my tubing with a very distint spirial pattern.
I don't know if or what that says about the EK block, but it may suggest that the EK excels at creating turbulence?
