That is because the standard max overclock for the Optys is in the 3Ghz range.
So 300mhz x 10 is the expected speed.. if you really want to see the limits of your ram set your multi even lower.
shoot. i would LOVE 300 x 10 but im sure its not gonna happen. i cant even do 267 x 7, lol.Quote:
Originally Posted by nn_step
which is better....faster mem speed or higher cpu MHz? and im i stuck with having to use a divider for 3.0?
CPU speed. using a divider isn't that big of a deal.
Optimize your bios settings and lower your ram volts to 2.6. See if you can get at least 270.
f it. i had it @ 3.0 before so i wanna keep it at that whatever it takes. im at 9:10 divider for now.Quote:
*sigh*
thanks for your help. sorry for threadjacking :(
ive tried optimizing my BIOS based on settings from this thread. a lot ive tried 2.5-2.7 + 0.3 and everything and still cant get past 265. its even iffy @ 265 too.Quote:
Originally Posted by Sniper.nkc
for some reason in CPUZ it shows the divider of 11/13 which makes my mem @ 231. where did it get 13 from? i thought 273 x .9 = 245?
god. im such a noob it hurts, lol.
My HZ will do around 276 on my Ultra D 1to1 at 2.7v 1T with my CABYE 148 but if I drop the multi down to like 9 and crank up the fsb and use a divider on the ram Im good for about 285.
Nice results dude,:D
man...everyone is doin 270+ and i cant even do 265 @ 9x multiplier. this blows.
well, I will let the pic speak for itself :-P
though I have yet to get it stable other then booting into windows, and NOT runnig a benchmark.
I tried over 3.0, and just locked up!.....................
if I can find the right settings I am sure I can get stability @3Ghz or higher
http://i38.photobucket.com/albums/e1...7/Desktop2.jpg
for normal use.. I have one question why does your desktop look like crap when you have a 7800GTX?Quote:
Originally Posted by phelan1777
because when I saved the pic in paintshop, it saved it as a gif I think and distorted it, I was trying to get the file to under 100kb so I could upload it on another site.
The screen and everything looks fine, just the program changed the image.
I changed the pic to a JPG, its clearer now.
When I said "optimized bios", go into bios and select "optimize." Press F10 to save, exit and reboot. Now go back into bios and set for 260 ~270, and adjust vdim to 2.6. Leave ram settings as is, do not make any changes. Try this and see if it helps. This is basically what I currently have for my HZ ram.
BTW, your 290 is damn good! Can you share your secret?
well...managed to find a stable 3.0. guess i have to sacrifice mem speed for cpu speed.
any suggestions on how i can improve this?
http://www.msu.edu/~nguyenbr/3ghz.JPG
@blazin-asian,
FYI, your HZ at above SP2004 run is @ 250MHz, not 231MHz. To make a story short - CPU-Z is wrong. Anyway... Set TRTW=3, Dynamic Idle Counter back to ENABLE and set your Drive Strength/Data Strength to AUTO/AUTO (in case you have it set differently).
I take, you tried to drop multi to x10 (even though, your CPU seems stable enough @ 3GHz)?
To be honest I don't have a secret, I just played around with timings, if I had thought about it, I would have had A64Tweaker open in the screen shot.
Oh well lesson for next time, I first started with stock settings, and just changed FSB/Multi, after that I played around with different settings, but as I fubared my install of windows, hal.dll is missing :-P, I have to reinstall...........again hehehehe.
when I figure out the settings I will share. But what you see is what I got so far, it seems the chip/ram doesn't like 300fsb :-(...........well to date anyway.
hmm...where does it say thats its running @ 250? i thought since im using a divider that it would run a bit slower.Quote:
Originally Posted by bachus_anonym
Some updated results. :toast:
Very nice set of HZ you got there. Nice work.
hey does anyone have any results for 0601's im having a bit of trouble getting these stable @265
My 601's tap out at 270fsb.
is this still at 2.5v vdimm? what DS/DDS do you use? prime stable?Quote:
Originally Posted by CRUSH-ER
:toast:
2.5v vdimm selected + .03 say's about 2.54v on the picture above. :)
I use 7/2 and yes they're stable.
thanks mate!
and you are using what bios? :)
Using 704-2BTA right now. :toast: :)
I have tried the 704-2BTA from TMODS and it was totally unstable! Went back to 623-3 bios and now I am stable.Quote:
