wow 1.44 VCore... time to sell the 3500 .130nm and get me a .09nm
I don't think I could get those clocks with 2.0Vcore let alone 1.44 :(
I am ready to do ALOT OF TWEAKS :)
I have posted a thread about my problem.. noone seems to know whats wrong.. maybe just bad mobo.
Onepagebook got this with OCZ DDR Boooster..
DDR557, 2-2-2-5...
Sounds not bad
Vdimm:3.6v
Since I will have 3x bh-5 kits soon.. Im thinking of just getting the MSI board
:banana:
Or.. think there more than 1-2monts until DFI s939 comes out?
DFI won't have 939 board I think, at least, oskar wu did not tell me that! ;)Quote:
Originally Posted by Arnar
I thought they were waiting for NF4, to come out with a s939 board with SLi technology
But all I know is what I have read here, nothing more
Dear Charlie:
These results are obtained from 2x256 and 2x512, both are HT 3x:
just for your reference! :toast:
2x512mb, Dual Channel:
http://www.e04hardware.com/ddr582.jpg
2x256mb, Dual channel:
http://www.e04hardware.com/ddr611.jpg
lmfao,
305@ 2.5-3-3-7-11-16
absolutely outrageous! I absolutely can't wait to get my hands on some Gskill!!!!!!
C
Onepage what volts on ram? 2.75? Also 1T or 2T?
no, it's 2.80v!Quote:
Originally Posted by `schr0et
2t cmd won't give you 8435 mb/s bandwidth! ;)
wow, if that stuff only scaled like BH5, we could hit 450mhz with 3.7v :D
Hi I'm not new to K8N NE02, but new to this thread.
It's been the easiest to OC A64 board I've had so far.:)
I'm only cooling with a MachI now, but as soon as my new MachII comes in I hope to get my 3500+ up over 2900mhz for 24/7 gameing goodness.
With this mem and cpu I'm peged @260x11 1:1 for 24/7 usage, and it's held up just fine for about a month.
Sure would like to get my hands on some Gskill.
Fear the Neo2 reign of terror!!!!
I love this mobo... ;)
How long can that run prime with those volts? Do you happen to know the steppings of your CPU?Quote:
Originally Posted by Blue078
My 260x11 @ 1.84 can only run prime for 2 mins before it fails and this is with the memory running fine.
Weird.
EDIT: Just tried 1.664V with the same clock, really odd its more stable at thoat volts, this is with my GT evap @ -63C
I dont do Prime :D quit messing with prime last year to buggy.
Hours and hours and hours of gameing is what I use :)
hm seems my 3500 is more stable @ 1.664V 260x11 1:1 than it is with 1.84+ Volts
Just played 30 mins of cs with no problem :)
Sounds like your holdup is elsewhere. I know I'm stable at 2900 with 1.63V but realy cant get her much higher even with 1.88 except for screenies. I think this is where lack of HT voltage option is hurting me. but not positive tho.
If anyone has trouble getting low temp readings with the K8N NEO2 downlaod the latest MBM5, use the K8N NEO Plat mobo selection, click settings go to temps, click CPU, and choose the first option for Winbond Diode 2
Mines shows -27 which is much better than getting 40C-163C
and this is maxing it. wish it were stable here.
I found that TRAS of 11 will damper your overclock severely. My Findings are here.
Originally Posted by Radelon
I will suggest "6"
There is a + setting that says 18%? Not 10%? :confused:Quote:
1.36beta goes upto +18%. I'm running it now and it works fine.Quote:
Originally Posted by xgman
Have you guys all modded your MSI board or?
If so, please say what mods and guides to them ;)
Im gona trash my Gigabyte and get one MSI
Most results so far are stock boards, but ofcourse a lot of phase change cooling too.
Hey, any news on the 1 slot ram booting with 0.09nm chip? Cause if i bought a 3000/msi combo I'd have to use this technique.
I really hope it works, cause I'm no good at hot flashing.
Tar.
btw guys u think this is a retail cpu with the cooler?
or would the asus a8v be better for me????
CLICK ME
I'm having trouble stabilizing at 1T. Running Neo2 with OCZ 3200el rev.2 (TCCD). Any one have any hints? Tried bios 1.3 and 1.36. Can't see a conflict sticking out at me.
