Nice work Brian, looking forward to more updates. Get some sleep.
Chew from what I have seen you do Here, I Promote you to:
"General Chew Of Xtreme Systems AMD Division" :clap:
I myself have 2 Honorable Discharges US Army
101st Airborne Division(Air Assault Unit)
*I also Salute All the Other testers here for a Job well Done, I'm a nobody compared to you guys
I guess W7 64 is out for this Ryzen 1800x and Hero crosshair6-DDR4 TridentZ 2x8gb 2400
or could it work for a while ??? before I re-format to W10 Pro.
I was not ready to goto W10 but after talking to Mr. Bill last night he said get with the program man.
nuts :(
Thanks vario
I'm already set at high performance.....what I wana do is just unplug machine take off phase.change evaporator head off from cpu
take CHV-Z board out.....hopefully the Hero CH6 asus board all screws and connectors will line up the same as CHV-Z board.
and put the new 1800x and CH6-Hero board and push the start button....and just goof off and play around on W7 64 Pro that's existing now on my ocz Revo3x2 ssd pcie drive...
Im looking right now for the new W10 64 pro dvd / cd to get in the next few weeks, I have heard everything runs better on W10
Im just a little scared to have to change Immediately to W10
I don't know what: quirks cng is ? I'm not a gamer just so you know if that applies here
I should note this so i will. Prime 95 is using bd k10 code or whatever you want to call it.It will need an update.The Stilt claims its not enough load currently. I have always respected his knowlege so if he said it its probably accurate.
I think like i did in review aggravating chip even more will be necessary to load it more to verify stability. So piss it off. Run cinebench. Literally spam it like i did back to back. Toss wprime 1024 at it. Open other stuff up. Just really annoy it. Cinebench prime 95 and wprime all at once.
I'm a bit disappointed with Ryzen. I was looking forward at dumping my 5820K and build a AM4 PC. After the reviews and mostly the poor overclocking potential, I don't feel like doing it anymore. They are selling the CPU near it's limit. Still, it's a bargain for that price and performance and I do believe AMD will reclaim some market. Too bad Intel still has got the lead in games.
Im not and i will explain why. In order to beat or be competive a reviewer needs to use intel 8/16 or 10/20 chip and board etc etc.
To beat it in ipc you need another chip and board. Pick one you cant have both.
To be best in games another chip
On this platform disable smt you get both in one socket at far less cost. One socket one platform.
So to game you need x chip on intel. But...at the cost of workstation performance. And vice versa
Ryzen is middle of the road happy balance.
I agree. Ryzen is a good overall CPU with very good price/performance ratio. I do believe it will gain the heart of many gamers. Nowadays CPU's are less important for gaming. With Ryzen you can put the extra cash on a better GPU and have far better performance than with Intel platform.
Something I was extremely surprised about, is the excellent energy consumption of Ryzen CPU's. A 8 core consuming less than Intel's 7700K (4 core). This was a big problem for AMD in the past.
The biggest deception is the overclockability of Ryzen. They do on average 4-4.1 Ghz from what I have seen. I was expecting something in the 4.4-4.5 range. But I am glad Intel is finally facing some serious competition.
Those are optimized for intel code. They were never a good test for amd. Its also for guys who want to think a quick stress test = stable
Prime 95 uses BD k10 code. Optimized for amd. Just needs code for ryzen to be more reliable for stress testing.
I honestly dont feel it was a deception as far as overclocking goes. I think peoples expectations were deceptive to themselves. Amd only admitted they could be oced they would all be unlocked multis.
Amd showed or someone showed leaks of 5.2 on ln2. That was a preety good indicator for me at least.
I was used of having huge headroom for oc with AMD. With thuban you could easily squeeze 1 Ghz more on the 1090T. With Vishera, you could even go past the magical 5 ghz limit on water. So I was expecting a little more of Ryzen. I mean, if you consider the turbo, you only win 200-300 mhz. It's very small margin. But who knows, they might work this out in future Ryzen stepping.
It could definitely benefit from like a c3 revision like deneb did or a respin. Still clock speed is and always has been irrelavant. I know we like to see big numbers but if a 3gig chip beats a 5gig chip in application X the 5g clock is pointless.
This chip reminds me of llano minus the graphics. I loved llano. :D
The chips you mention have one thing in common, they were both on a somewhat mature manufacturing process - Thuban on 45nm, Vishera on 32nm.
However, if you look at the first chips AMD made on new nodes, the picture is quite similar to what we see with Ryzen.
Deneb, 45nm, wasn't a really great clocker in the beginning but got much better with the C3 stepping
Llano, 32nm, even though a mature architecture, it was not particularly great for overclocking either
Kaveri, 28nm, improved over time but started rather slow too
I'm confident that Ryzen clocks and overclocking will improve over time, as the process and manufacturing matures.
Yep. Search 955 unleashed on forums. Deneb launch 4 gig air was golden and my abilty to get it stable there was questioned.
That particular chip was just a lucky low leakage well balanced chip.
C3 saw chips up to 4.5-4.6 stable over time.
My expectations are somewhat conservative but i think 4.3 on ryzen with optimizations could be realistic.
Would not be surprised if we see a 4.2 4.3 xfr chip 6 months to a year down the road.
No clue if we will be doing that on 65w chips all cores stable though especially on current boards.
I fully agree. For the average consumer, overclock doesn't matter. But for someone that loves to overclock and to squeeze every single mhz, it is somewhat disappointing. Going from 3.8 GHz to 4 GHz doesn't give you the thrill of going from 3.2 to 4.3 GHz. But I agree, it's only numbers. My FX 8320 would do 5 GHz with only 1.45v, yet it's beaten by a stock 5820k. But when seen trough the eyes of an overclocker, it matters :)
Thats where i come into play. Im here to help you guys get the most performance out of the chips as i always have done in the past. We have oc restrictions so time to chase hardware configs memory speeds and whatever performance we can extract at our given clocks reliably.
Total system performance matters most.
Have you Test If the Stress Test oft AOD works?
With the FX i get more Heat with AOD whan Turbo was on
Without Turbo i get more Heat with Prime
Fastest and highest Heat with this Settings
https://abload.de/thumb/prime9ssvc.jpg
Also an good Job to heat up with Turbo does the realy old Benchmark nuclearus!
With this Setting the FX heats with Turbo more up than AOD
But Start for every Core an extra nuclearus!!!!
So finaly 8x nuclearus was Running
https://abload.de/thumb/nuctestzfskg.jpg
Thx techtrancer. I will look into this and run them at settings i used for review.
But think is only good for max Heat Stress!
I also use Prime large & smal
And Maybe the best FFT for highest Heat with Ryzen is an other.
Also Maybe an other nuclearus Setting
An good way to See How much Power the CPU use at the Moment of Stress is SIW
There you can See How much Watt it use
It's not the right Watt, but you can See If it's most ore not.
Also if it's nonstop high ore if it goes up and down
So you can find the best FFT & nuclearus Setting for max Heat easier
Im more concerned with imc tbh. Normally i can get a random thread drop if imc or memory has instability. I am unable to trigger this with current version. I can get heat up really good just pounding all threads simultaneously with multiple stress tests.
Id rather use 1700 for that with this board. Swapping to 95 watt part changes alot.
If one was to do pwm temps testing and analysis on gaming 5 without using 95w parts as well it would be rather inconclusive and misleading.
Temps are hot to the touch with 1700 no fan. Temps will burn you with 1800x no fan same volts same clocks.
My normal 24/7 cooling setup^^
Works well since 939
Never distroy an MB, RAM ore CPU
https://abload.de/thumb/img_892082bom.jpg https://abload.de/thumb/img_1225kujo4.jpg
Have you been able to complete a 32M?
Hmm, I will change OS.
