Push it higher plz :P try 13x200 @ 1.85vcoreQuote:
Originally posted by emp
AQYHA 0350 TPMW
Priming at 11*200 @ 1.45V atm (havent tried lower voltage.. dunno why..)
AQYHA 0350 TPMW
12x200 @ 1.65V primestable have been reported at another forum (early testing and not burned in yet). Same stepping as emp's. These chips seems to be damn good! Hope they like high vcore. :)
emp, where (and when) did you buy your chip. I maby should buy one too. :D
As a matter of fact.
Priming 12*200 @ 1.65V atm (42C Aircooled)
Pretty nice for a processor right out of the box! :)
My old 2500+ wouldnt even touch 2400MHz at any voltage.
Ohooo, I have to buy one, wher did you buy it? Can you please tell me, itbutikken.dk right?
Correct. itbutikken
Hmm, I think I will order one soon. It sounds like it is as good as the mobile 2600+ chips...
Kan du ge mig hela steppings koden ala siffror m.m (allt som står på platan)Quote:
Oh, I forgot to mention, it's with a crappy Igloo cooler and load temp well over 50C.Quote:
Although I would still like to know if these continue to scale up with 1,8-9v and more. If they do they can reach insane speeds.
Ok Lastviking.
AXMD2400FJQ4C (duh)
AQYHA 0350 TPMW
Z378703L30164
Thats everything on the processor.
Oh wonderful clock, i'll get mine tomorrow, hopefully we got from the same delivery.. so a get a AQYHA 0350 too :)
also mine ordered from itbutikken, and they sent it this monday.
Hmm downgraded xp3000+ .... We need some higher vcore action.....cane you try 1.85v or higher?Quote:
Ok Lastviking.
AXMD2400FJQ4C (duh)
AQYHA 0350 TPMW
Z378703L"30"164
If the old rumors is true...
How can you say that it is a downgraded 3000+ ? what in the stepping tells that?Quote:
Priming: 13*200 @ 1.8V. I tried lower voltage but it didnt like it.
Temp is 45C now. I'll let her chew at this speed for a while.. see how the temps end up.
Damn you lucky European basturds:D
Nice to see some results finally:) I've held off jumping on the mobile bandwagon in anticipation of these 35-watters. I want them here in the US now.:mad:
Hmm, I'm still waiting for my 2 CPUs to arrive.:stick: :rolleyes:
Yeeeeehaaaaaaaaw!!! Got my CPUs today! Both are AQYHA 0350 TPMW CPUs. Can't wait to test them. :banana:
I cancelled mine, but now that I see these incredible results I had to order again. :)
I got my at the mail, are going down to get it soon. That and a aopen fsp400w. Will be a oc weekend i belive.
I dont know if its to high but it would be nice to get it to 240*11 on my modded nf7-s r1.2 with my old corsair 512 stick only sc, until i get some more mem, but i may(!) have a place to buy KHX3200/256 will be 2 of thoose then.
Have one of my two chips in my setup right now priming at 200x11 at 1.45V (set in bios, so real voltage is about 1,42V).
Update: 2400 MHz now at 1,6V in Bios. Real voltage Ã:banana:s between 1,53 and 1,6V (average about 1,55V).
REALLY NICE CHIP! :banana: :toast:
These chips sound sweet!
Just ordered one myself, though Ibutiken says none in stock till the 26th so I've got a bit of a wait.
Anyone seen what these chips can do with a bit more voltage yet?
Even with air cooling, 2700-2800 MHz seem to be possible at higher volts.
I could boot at 2700 MHz, but stopped, because I was scared when my Shuttle AN35N-Ultra board started making whistling noises. Obviously it couldn't handle the high CPU power. Very strange. Was in windows at 2600 MHz already, but same symptoms, so I backed down for the sake of safety.
I have also orderd one from itbutikken, but I also have to wait until the 26:th :(
I got it now. 2100MHz @ 1.42v (175x12) on a crappy ALUsink..
AQYHA 0350TPMW
Nice. where did you get yours from?
