2 accidental event...
one defrag (scheduled)
one avi file not compressed.
ok is accidet, but with my drive i wanna make everythink.... not worries about longevity.... but i need costant performance from the first to the last days....
Ok, i see..
defrag issue will be the same with every ssd product i guess....but since compressed/incompressed file performance of SF drives has a large gap, M4 may be a fine solution
SSD are still too ridiculously expensive. I just cannot see spending that kind of money and trusting my data on a drive/technology that has not been time tested to the extent that Magnetic HDD storage has been.
I would have thought after what 3 years now these things would be at a reasonable price point to encourage people to start transitioning over by the masses.
I agree with you, this put the To at more of 1000 dollars (and again, here it's more 1600dollars ( 400dollars for a 240-256) .... who is completely crazy when you can buy a WD Black 1To Sata6 for ... less of 100$ ..
But personally i use SSD's only for the software and main C:, all files are stored in 2 HDD of 1to + i have 2 old WD blue 500go for my old files ....
There's absolutely no interest to use a SSD for storage..
1st user reports, I wish I knew enough japanese to ask this guy some questions.
http://translate.google.com/translat...%26prmd%3Divns
Edited post. (wrong ssd previously, here is Force 3) http://club.coneco.net/ImgPopUp.aspx...&rd=66707&ps=1
here is another post which looks good: http://translate.google.com/translat...%26prmd%3Divns
My reluctance is with the initial data writing to the O.S prior to it being written to the storage Array. Most people work with Data within the Operating System prior to saving it. Like I initially stated the technology has not been put through the paces for years by the majority so I will not trust it for my data prior to that being done. So, I will stay with time proven and tested slower magnetic recording technology until that time comes. Although SHA-1 & MD5 Checksum generation and validation on the grounds of a personal scientific study could answer these questions and concerns that I raise.
Perhaps at some point I may be inclined to carry these tests out to satisfy my own personal curiosity.
here are benches from different people http://img219.imageshack.us/img219/6994/ssdze.jpg
Not as impressive as I had hoped considering this program shows maximum throughput.
http://translate.googleusercontent.c...pgsVfpGkZ_7yOw
http://img807.imageshack.us/img807/3041/26590586.jpg
AS SSD (my c300 does better than this):
http://www1.axfc.net/uploader/Sc/lin...=Sc_239109.png
Well, ssd for data storage is absurd for the time being.
However, i see you bought 36gig raptor which was around 30% faster than normal 7200 drives and cost per GB was 3x.
SSD for system/programs gives you MUCH MUCH MUCH more speed than 30% .Theres no point at this time to NOT have an ssd for a boot drive.
It really makes all this inefficient windows os/NET framework much more bearable.
Im new to this but what do you mean by uncompressed data?I just got a corsair force sata 2 ssd and dont know if I need to compress it to get faster performance.
So the force gt is going to be even faster than this drive?Im about to upgrade to a faster drive and will hold off if the GT is that much better.
Yea, I bought that drive back when I was like 20 years old(I'm now 26) and living paycheck to paycheck while living in a craphole, party apartment with 4 buddies =/ These days I wouldn't spend on something like that. I'm actually surprised the drive is still going to this day, my cousin purchased one from the same batch and his went down over a year ago.
5 reviews so far. Not stellar. I'm disappointed in this, thinking of refusing the order. Which drive is as reliable as the c300 but will be noticably faster other than M4?
Really. Why have a lot forums said the Intel 320 is faster than the 510? I kept reading people recommending it over the 510. If it's faster than the 320 than I might get the 510 instead because I was considering the 320. I'm strictly speakign of the 120gb models.
Yes, and OCZ wasted no time to "correct" specifications: :D
http://www.ocztechnology.com/ocz-ver...i-2-5-ssd.html
http://www.ocztechnology.com/ocz-agi...i-2-5-ssd.html
"Maximum 4K Random Write: 85,000 IOPS"
"Small file I/O performance is measured using Iometer2008, Queue Depth 32, 4KB Aligned; Logical Block Address (LBA) range: 85% of total drive capacity"
"Small file I/O performance is measured using Iometer2008, Queue Depth 32, 4KB Aligned; Logical Block Address (LBA) range: 8GB Incompressible"
Oh, I love marketing :rofl:
Your post was in response to mine. And IOMeter tests had nothing to do with my post. The CDM/AS SSD results that users are starting to post are the same or slightly less then what I am getting with the Solid 3 drive. So users are paying a $30.00 - $40.00 premium for a product that brings nothing more to the table over the Solid 3. And as long as you are going to quote OCZ specified performance claims why not also post that AS SSD results are also shown? Or would this not fit the current agenda?
Finally one review. Just hope it's not biased and another comes in soon
http://www.kitguru.net/components/ss...gb-ssd-review/
And what was the problem with that comment that I made? You could not see how the IOMeter config files were tuned to reach a predetermined outcome? If those files didn't put things into perspective for you a benchmark that cannot be altered should.
http://www.pilipali.info/misc/asbench.jpg
http://www.overclock.net/ssd/1028614...corsair-2.html
