Updated, thx for sharing, so few 2500Ks around... even if it doesn't reach 5ghz plz ( I have 3 lol) still post ya results :)
5000ghz at 1.35 in bios
http://img43.imageshack.us/img43/1594/linx5000.jpg
Uploaded with ImageShack.us
Crazy Olivon 5.2 at 1.56Vcore, would never go as high for daily usage...
List updated, keep them coming !!
will do,
2500k batch# L036B120
g.skill F3-16000CL9T-6GBTD (was my 1366kit, only using 2x2gb now)
bios 1.275v, LLC ultra high
cooling: hk3.0 & EK gtx470, 480+240 rad + a bunch of fans
http://i52.tinypic.com/5z3603.png
http://i51.tinypic.com/eirwxw.jpg
:wave: LinX ist to easy for Sandy Test it with Prime26.4
Batch L042B074
http://www.abload.de/thumb/52ghz1.524vcoreaces7oy.jpg
hey leeg you updated list ? Need to know gonna see if i can pick up a few good batches for testing..
Yes list is updated till the 23 pf january (just not ace's result)
See first post or click on the link below... too bad not many 2500Ks are around...
Sandy Bridge FPO List
2600k @ 5Ghz on Noctua NH D14 stock fans
batch: L042B074
1.365v bios - 1.336v idle - 1.392v load
MSI P67A-GD65 1.8b6 bios
2x2GB Team Xtreem LV
2600K batch L041B741
Voltage set 1.365 in bios.
On water Apogee XT Only CPU on loop
this test was with vengeance 8 gigs, going to switch my Dominator GT's C7 in.
Two cores higher than the other two because I think the block is STILL sitting on one of the caps
next to socket. I do have the gigabyte friendly version of the block. I may try to dremmel it.
it MIGHT be the way i oriented the block also. because it looked like the proper way the baseplate with
the screw in the middle looked like it would still hit. so I turned it 90 degree's. I run my board horizontal.
if anyone can recommend a block with smaller baseplate, please do.
I also have
L039B214
L040B208
L042B208
To test when i get a chance.
http://img210.imageshack.us/img210/9522/2600k49.th.jpg
List updated , thx all for testing !
Updated at 29th of Januari
Sandy Bridge FPO batches
What did u updated? I've putted screen with my one and its not listed...?
It's there now, just didn't type ya name in the frontpage :p ( was in the latest excell sheet though )
Lee,
As you know, I refuse to degrade my chip stress testing it with linpack or Prime anymore, so it's ok if you don't want to include mine in your result chart.
I only use 3d gaming and my Deep Rybka 4 chess engine (and some Vantage :).
But here it goes:
2600k
L045A998 <--has to be a RECORD high for a batch
4.5 ghz 1.265v-1.27v (load), AUTO (bios; shown as 1.35v; this was AUTO), PLL OFF, LLC OFF: Venemous-X (max prime small FFT 65C), fully game stable.
5 ghz 1.450 (load), 1.39v (BIOS-manual OR AUTO=1.39), PLL On, LLC ON (Max Deep Rybka 4, 8 threads: 75C; running Chess opening Analysis for over an hour)
Temps reach 89C and rising on Prime small FFT with the Ven-X, risk chip damage by testing any further. Maybe there's an issue with the install, since the Ven-X does swivel; (others said it does that for them too, but does NOT budge one bit with a TRUE);I don't know, but I installed it as perfectly as can be expected, outside on a clear day, so there were no mistakes.
TRUE Black fared slightly worse in temps (despite being unable to swivel it at all; using MX-4; the mount was as perfect as possible; the Ven-X did swivel (tension knob barely helped; I suspect the bases from TRUE to Ven-X are very slightly different, but was otherwise secure).
hey leeg u added these
http://www.xtremesystems.org/forums/...d.php?t=265978
http://www.xtremesystems.org/forums/...d.php?t=265583
:banana::banana::banana::banana: load of batches in the 2500/2600k thread too..
my preference is Prime95
but my batch need 1.4xx for 5.0Ghz not so good
My PRECIOUS! (also posted here first time: http://www.xtremesystems.org/forums/...=1#post4726375)
http://i55.tinypic.com/34gjy9x.jpg
http://i54.tinypic.com/2ilg7c9.jpg
http://i53.tinypic.com/2zeza4y.jpg
with 24/7 settings:
CPU testing:
http://i52.tinypic.com/2euj1jb.jpg
http://i55.tinypic.com/5f26j5.jpg
Memory testing:
http://i52.tinypic.com/153xykz.jpg
http://i56.tinypic.com/rkanph.jpg
Benching settings:
http://i51.tinypic.com/2mh7on5.jpg
http://i55.tinypic.com/2en1coz.jpg
http://i52.tinypic.com/t8nqmh.jpg
Movies during bios settings and booting +3DMark 2006 full@ default setiings on videocard:
http://www.youtube.com/watch?v=c1rSKb6wgeI
http://www.youtube.com/watch?v=IMWAClNWv68
I'm wading through a few threads to gather data lads... but a 32M run at 5.5 or such is pointless. Batches don't 100% warrant good results either. There still is some luck involved or being able to test a lot of different CPUs...
Google Docs version of the Excel file for those who don't have office:)
https://spreadsheets.google.com/ccc?...thkey=CJOF6ZIF
@Leeghoofd
I've been able to improve on my initial 2500K o.c. originally submitted here: http://www.xtremesystems.org/forums/...0&postcount=50
Now today the same chip but using a different motherboard... submitted here: http://www.xtremesystems.org/forums/...postcount=1528
Np mate, added... was it the new cooling , the new board or the mix that got you hugher at less volts ?
