bingo13 glad you brough it into your own thread. Gary you never will back off, you tried to PM me my inbox was full i emptied it. I am asking your guy here questions becuase his write up is a ASUS marketing ploy, hey here is a Sandy Bridge OC guide that actually is an ASUS motherboard OC guide/review. Its ok because I have a real OC guide I made myself after a few weeks of testing and more than one chip. It has nothing to do with Gigabyte though. This guy restated ASUS marketing, do you know what I did? i wrote my article then saw the Gigabyte media kit and used them to back me up. Actually no one had anything good to say about what I said, no one said it was wrong either. Here is what happened.
Shamino asked questions I responded, he didn't like when I put down Volterra, becuase he pushed for it in the Classy. But now he works for ASUS so you tried to get him to make me look bad.
Next bingo13 you tried to make me look bad then you made threats, then you made more threats, how do you know I didn't take the board to a university I work at and have it tested? you really have no idea who i am man. But you are right I don't have your board, but I don't think it mattetrs unless Chil totally did a 180 and change digital PWM design. Chil better than Volterra, seems that isn't true, as far as most of the community is concerned, but you are saying transisent responce is better. Well this article says different:
http://www.theoverclocker.com/backis...r-Issue-09.pdf
Then a last guy came into the thread and said the way i cam e to my conclusion was wrong, but that either way could be right, and that digital pwm transient responce might be faster by now, which is a real way to say hey there is nothing wrong but it might be different now even though its not i just had to say somthing to make you look bad.
Now you hate that article saying it was written by someone that works at interstill, you , ASUS marketing Manger, were corrected by a very nice member that he was an intern at the time.
Next we move on to does it matter? Hey if transient responce was that important, how come these boards aren't VRD 12 Certified? I see it no where in your marketing, but surly if Gigabyte has it written everywhere you would think it woudl be there for you guys.
Back on topic, "OC Guide" is short of true. you don't need to turn on C1E and EIST, you don't need to lower any of the other voltage, you don't call any OC Turbo short of confusing people. Next lets get to this, a boot into windows is NOT stable don't go raising multiplier. Any overclocker knows you have to test the stability, as yes this chip boots into windows it can run benchmarks, BUT try running Prime 95 or even better intel burn Test to test for stability.
One of three things will happen:
#1 processor will do the Stability test and pass
#2 processor is not do it and give you a blue screen before it is finished
#3 Processor will over heat becuase of its ability to exceed TDP and thus thermal throttle.
Most of these benchmarkers might wanna rerun their benchmarks, as I have a few aircoolers here and some just cannot handle the heat of these processors at load.
just somthing that really bothered me.
Also not every boot into windows is stable, most are 1/2 stable, aka able to run benchmark, but may throttle, or crash.
Can you explain to us why you want to keep on C1E and EIST?
Can you explain to us the question I had about the volterra data sheet?
Now back to my question about you guys taking 8x of lanes and making it x32, isn't this where the NF200 got its bad rep for increasing latency? Also does those switches increase latency?
I guess we gotta wait for a site to bench it against each other. Pity I also have my SLI setup on normal NF200 setup, I am just going to compare it against X58 SLI, if it loses then so be it.
