Thank you, sandybridge is just to replace the 1156's.. Hope they bring out the high end sandy bridge cpu's before 2011 :down:
This isnt the best move for Intel to make seeing as their competition is starting by releasing their new architecture with 8 cores 16 threads in the beginning of the year. The Bulldozer architecture also has the AVX so Intel had better hope their CPUs Clock like nuts.
Even if nobody wanted the new intel chips over the new amd chips, intel would still sell more by virtue of their manufacturing edge they have over amd. Intel survived Athlon 64 on sheer marketing and manufacturing alone. Intel also advertises, so they have that brand name zing, while AMD... are f'ing retards when it comes to advertising their products. AMD could seriously take Nvidia to task if they would just start advertising Radeon graphics as a brand name... instead Nvidia is still the brand name in the mind of the uninformed.
Its not Hyperthreading. AMD is using their Cluster Core design which is 2 sets of execution units fused between 2 128bit FP schedulers (AVX). Each set of execution units gets its own thread. Hence one Cluster Core and 2 threads. Bulldozers full design calls for 8 Cluster Cores and 16 threads And shared L3 between all cores.
Intel seems to be keeping with their same tried and true system but on a new architecture.
execution units are "pipelines." 8 for int and 2 for fpu(FMAC) per "cluster core."
keep in mind that top-end BD will only have 8 cores, 8 threads, 4 "cluster cores" for desktop(zambezi).
16 cores, 16 threads, 8 "cluster cores" is interlagos. a server part only.
SB 3Q 2011 top-end desktop will be capable of 8x256 bit AVX(although MADD only; or 8x128 bit fpu.)
Their whole naming and designation scheme has gone every-witch way, thats why i was slightly messed up with my info. After reading a lot more in some different places its slightly clearer but cant wait till next months info dump. Hope Bulldozer clocks like these Hex cores do. But the 2011 round of the Intel VS AMD should be very interesting.
those are ancient 45nm lynnfield chips, big deal...
compare it to a 32nm chip ie the i5 600 series and suddenly those clocks dont look very impressive at all...
an i5 680 comes clocked at 3.6ghz, and no, thats the default clock, not turbo mode...
sb looks like a quadcore clarkdale with better igp, but who cares about 2 more cores and igp? :/
lets face it, in a normal usage scenario you wont be able to tell a sb and clarkdale machine apart...
yeah like 6% and who cares about power in a desktop machine... :P
1. i talked about ipc, and not the performance of cpu a vs b, what intel decides to bin turbo mode at etc has nothing to do with what a cpu design is capable of
2. at stock speed and looking at the cpu level perf with turbo mode and all, yeah, but when overclocked even that comparison shows a lead of gulftown/bloomfield.
again, if you talk about IPC they are the same.
Bloomfield sometimes has advantages when there are apps that need lots of bandwidth, but in general they have the same IPC if you remove that advantage by running bloomfield in dualchannle mode they performe exactly the same.
Again get your facts right. :p:
its harder got stock 3.6 GHz six or octa cores than dualcores...and TDP up to 130W too
where is my LGA 1366 32nm 260€ cpu :'(
*still dreaming*
sb is a cost down of 1155 for OEMs...
remember 30h6's clarkdale review?
i dont know if the efficiency has improved now that everybody knows how to tweak the gmch and push for high qpi... at stock speeds maybe... but when overclocked... i dont think so... why do you think all top scores are still done on 1366 and 1156 is waaaaay behind?
god, you just love wearing your 4ss as your hat, dont you? ^^
Because there are some limitations for socket S1156, e.g power layout of the socket iteself, the obviouse dual vs tripple channle and more pci-e lanes and some other minor detail, which makes S1336 the better ocing platform for extreme ocing. But this doesn't change the fact that they have the same IPC.
If you look even closer, you see that normal 9xx dont clock much higher then the 8xx (check records on hwbot, they are all ~5,7-5,8ghz the exeptions are the 975 and the 980
Yes I do, the facts are there I just pointed them out. It's not my fault that they don't match with your opinion... :p:
I think they'll be interesting and hope to get my hands on 'em early :p: :D Liked 670's for Pi and frequency shots, sandybridge might be doing good there :hehe:
what, im calling him rude, whats wrong with that? i didnt mean it as an insult and i dont think he saw it as one...
hornet?
compare the highest scores of 1156 and 1366... there is a pretty huge gap, not just 5% or 10%...
well thats rather a hint that the extra vcc and vss pins dont really matter all that much, doesnt it? :D
no, i agree, you were right, the ipc at stock clocks is about the same for 1156 and 1366... what i meant is that you seem to really enjoy pointing out that i was wrong :D
thats still a bit ahead... 10 core, 4 channel will come in q2 a far as i know. and yes, there are already plans for dual socket highend boards... seem like evgas sr2 has motivated intel to bring skulltrail back to live :D
i really dont see the point in a 20 core 40 thread 8 channel highend platform though when its hard to find a game that uses more than 3 threads and scales with more than 2 channels... actually most games barely scale when you go from single to dual channel, hah... :D
for crunchers who want plenty of cores sb will be interesting, same goes for servers... i just really really hope the dualcore mobile sb chips wont dissapoint... mobile clarkdales offer better performance than culv but you lose 1-2h battery life, which for me just isnt worth it...
aww hell no !
not going to upgrade this soon again.. stop making new stuff intel !
