Is it possible to unlock the 16x multiplier on 790fxt-ud5p?
Amazing results, OCM XPC! Disregard distractions, keep them coming!
Amazing, simply amazing.
When will these rams be available in market?
I really like AMD Phenom II X6 CPU with 890FX MB , because there is high C/P value and running over DDR3-2000 MHz (4x2GB) .
I think the new value is useful for Graphic users of Photoshop and PRO-E tools .
I tried that the Verification of AMD Phenom II x6 with 790FX MB can not run DDR3-2000 MHz .
This time , to try the combination of Phenom II X4 C3 version with 890FX MB running barely DDR3-1980 MHz ( 2x2GB ) .
Task Manager >> CPU usage 100% , Physical memory usage 3.88GB/4GB
MemTest 100% Pass
http://www.coolaler.com.tw/ocman/D3198/1004.png
MemTest 500% Pass
http://www.coolaler.com.tw/ocman/D3198/1006.png
MemTest 1000% Pass , burning 2hr.
http://www.coolaler.com.tw/ocman/D3198/1008.png
Hyper PI 32M/4 Cores testing
LOOP 20
http://www.coolaler.com.tw/ocman/D3198/1010.png
PI Finished
http://www.coolaler.com.tw/ocman/D3198/1011.png
Go to NewEgg.
G.SKILL Flare 4GB (2 x 2GB) DDR3 2000 CL7 Model F3-16000CL7D-4GBFLS for AMD Phenom II X6 CPU
http://www.newegg.com/Product/Produc...82E16820231370
G.SKILL Flare 4GB (2 x 2GB) DDR3 2000 CL9 Model F3-16000CL9D-4GBFLS for AMD Phenom II X6 CPU
http://www.newegg.com/Product/Produc...82E16820231371
G.SKILL Flare 4GB (2 x 2GB) DDR3 1800 CL7 Model F3-14400CL7D-4GBFLS
http://www.newegg.com/Product/Produc...82E16820231367
G.SKILL Flare 4GB (2 x 2GB) DDR3 1800 CL9 Model F3-14400CL9D-4GBFLS
http://www.newegg.com/Product/Produc...82E16820231369
Flare series is designed for AMD.:up::up:
Does anyone have the slightest idea what chips are on these sticks? Powerchips maybe? :shrug:
i forgot it, how much voltage using for RAMs?
Hi, I'm wondering which set to buy, Flare 1800 CL7 or 2000 CL7. I'm using Asrock 890gx extreme3 and phenom 1055T, is the motherboard going to be a problem for the memory OC. The second one costs extra 50 Euro, and I'm not sure what kind of improvement it's going to make when itinsn't used in a benchmark.
That depends, how good is your current ram?
How exactly depends of my current ram, I'm going to replace it with the GSkill i mentioned. I'm just wondering if my motherboard is going to be a problem.
Hello ,
ASrock 890GX Extreme supports Dual Channel DDR3 1800(OC) ,
GSkill Flare series is designed for AMD Platform ,
DDR3-2000MHz @AMD Platform is exciting . :up::up:
You can check G.Skill Flare series supporting QVL of AMD-MB .
So far , I found only ASUS AMD-890FX MB supporting DDR3-2000MHz.
nice ram speed and timings.
