i really thought it was news section untill u mentioned :ROTF:
lol cant believe people find a reason to hate on thuban already.. again price/performance is gonna be great compared to intel. oh and you can use your old mobo for it, or use your new mobo for more than 2 years :p:
Now you don't need a $250+ mobo to run a great cpu. Except for some people, i7 quads are dead.
omg, nice AMD. Wprime etc....
was digging around looking for some i7 comparisons,, heres cb 11.5 64 bit, with i7 930 & phenom x6 both @ 4.2ghz
http://hostimage.co.uk/08-Apr-10_0F69-4BBDB0E5.jpg
http://i70.photobucket.com/albums/i82/mrjohnson2/vv.jpg
sweet performance at 4.2ghz.......it beats bloomfield. Cant wait to get one!
There you have it.
i7 930 @ 4.2ghz = 7.20
X6 1050T @ 4.2ghz = 7.38
6 Physical Phenom 2 cores, are on par or surpass an i7 9** with 4 phsyical / 4 logical cores. (In Cinebench and hopefully other heavily threaded apps/benchmarks)
That's the first time in years, outside of gaming, that AMD has had a chip to match Intel at the same clock speed.
AMD's brute force method of throwing more cores @ i7's hyperthreading seems to have paid off.
That being said, if scaling is linear than a $295 1090T @ 3.2ghz stock should be able to perform within roughly 90-110% of the i7 960 @ 3.2 stock in heavily threaded benchmarks.
As far as gaming goes the Ph2 is pretty much equal and in some cases even faster than the i7. Bloomfield takes the cake in the more CPU aware games like Far Cry 2, or Resident Evil 5 and Thuban's 2 extra cores should help with that. For games that can only utilize 2-3 cores, The 1050/1090T's respective 3.3/3.6ghz Turbo modes should make for an extremely interesting set of numbers.
How is that not a win? What is there not to be impressed with? 2 more cores added to the same process node while maintaining the same thermal envelope as their last flagship quadcore and from what we've seen just as clockable as their quad counterparts.
Seems like a good deal to me. The greatest thing is, anyone with an AM2+ motherboard is going to be able to breathe new life into old machines.
This is just another much needed step in the right direction for AMD. Every single CPU refresh that's been released has brought performance improvements even when based on the same stepping. i.e 955 c2 vs. 965 c2 This started all the way back with 940, X3 720 came out and it was a better piece of silicon, then the 955, then the 965, then C3 and now Thuban.
I run both Intel and AMD and It's not hard to see that this is good for everyone. This should definitely rumble Intel's feathers and if anything it will give those absolutely blinded by blue some nice price drops on CPU's for their respective platforms.
I don't understand why people don't want to see AMD succeed.
all of a sudden people forgot about the 4 logical cores making a total of 8 for Intel vs 6 for AMD.......but noooo........it takes AMD 6 cores to Intels 4 now....hmmm!
Which mobo though?:D...Other than CH4
This Thuban is good, very good but it remains to be seen how it holds up against Intel in more than just one benchmark.
Either way you look at it, it is not blowing Intel away like Intel blew away Athlon 64 with their Conroe back then.
I think we should just stop making those AMD-Intel comparisations and enjoy what we're given. ;)
Following the trend, the name Bulldozer makes sense?
Too bad the NDA will expire in at least 1 week.
Nice, 4,2G with retail chip?
Good Cinebench performance too
I wonder how stable it is with these clocks
Keep in mind that the AMD K10.5 cores are much smaller as the the
Nehalem cores. Here a compare at 32 nm
http://www.chip-architect.com/news/L...Westmere_s.jpg
So the Nehalem cores are 10%-15% faster in single threaded applications
and another 20%-30% through the use of Hyper Threading. They achieve
that at a cost of being 1.8 times larger.
Regards, Hans
I never realised that the cores were THAT tiny! Miniturisation is incredible.
You have hit it on the head
This is my post where i was saying the same thing...
I do stand by my est. of dual llano < dual sandy bridge < quad llano < quad sandy in performance tough.
Hans thanks for posting that analysis ,I've been saying similar thing for a while now in Deneb Vs Nehalem threads.Now we have your post backed up with nice images you compiled for all of us to see ;),good job :up:
The two SRAM tiles of the L2 cache are below the "B" of Sandy Bridge.
They are longer but also less wide as in case of Westmere so the area
is about the same in both cases.
A good candidate for a Trace cache would be the larger square tile
below the L2 cache and above the location of the L1 instruction cache
in Westmere, which is located at the bottom edge in the middle.
Regards, Hans
A bit larger version:
http://www.chip-architect.com/news/L...s_Westmere.jpg
:yepp::yepp::yepp:
reminds me of my old post.
//more at [ OCN ]Quote:
SuperPi is an antiquated benchmark that assesses core performance using an antiquated fpu x87 instruction set. It is a grossly inefficient computer program that uses floating point units to calculate pi and "evaluate" processor cache performance. It's not by any means a "real world" reflection of todays modern cpu's microarch capabilities. It's like running a horse(fpu x87 instructions) down today's paved interstate(the cpu hardware), when all the while a car(newer simd's) are available.
SuperPi fails to take advantage of newer instruction sets, and hence also fails to evaluate modern-day hardware capabilities that newer processors support and are designed with. The FPU X87 instruction set was developed for an external co-processor dedicated to computing mathematical tasks and worked with the 80286/80386 microprocessors. Now if you havent heard of the 286/386, then you know SuperPi is that old.
