I think the last digit determines if its 400mhz or 500mhz, because the 960T has 400mhz boost and so does the 1090T.... :shrug:
Yeah it's very complicated :rolleyes: : 400Mhz over stock clock across 3 cores if model number ends with "0" or 500Mhz over stock clock across 3 cores if model number ends with "5" . So with 1090T model you have 125W 3.2Ghz hex core OR 3.6Ghz three core,depending on the load scenario.The TDP is never crossed ,it's a guarantee(dedicated HW inside the chip,not temperature based).It can only be the rated value or below the rated value(95W or 125W),no matter if Turbo kicks in or not.
that's orange to apples... What you said can be reversed when looking at games today, most of them use 2 cores so they will get a nice boost in CPU power.
I bet you will never have a case where there is a single compute-intensive thread, unless the intention is to intentionally isolate one core, for some strange reason. Or if you run out of date and obsolete software. Both seem pointless, unless you are bias for or against one architecture.
so? You run 6 instances and your done.
Turbo on Intel or AMD is not for well threaded apps, it's for old/low-threaded apps, to give better perf.
In virtualization you need more cores mainly, so you can run more instances.
probably thinking like a top of the line cool n quiet for the oc'er ???? 4ghz at a certain volt ... and when you put more load certain core will overvolt and oc to 5ghz if the heat can be taken out of equation??? if so we are thinking about the same thing
same 45nm fab process so i doubt that they have one .... queue the LHE joke
I think this will be my next upgrade :)
Im going back to AMD!
@jmke
And reviewers have their samples?
2 more weeks to go ...
BTW it will be interesting to see how 6-core is coping with DDR-2 memory. Will it show bigger difference going to DDR-3 than Phenoms X4 were showing?
If AMD will use faster NB clocks then I bet it will!
No cold bug again :D
hm, il like for overclocking, better than PII C3? Or simillary (air/watter)?
come on! show us the results already! :D
how will the 960T price compare to the 965?
that will really be awesome if these unlock
960T + asus 890gx for the win
will these be available April 26th or is that just a paper launch?
960T with unlocked to 6cores will be my next cpu
i think, it will not possible unlock 960T up x6 (different solutions than core Denebs)
960T is Thuban based,so unlock is a possibility.
