Powerchips don't scale with voltage (at least not much). I'm beginning to think they are Elpida since GSkill is releasing a 9600 at 1.8v
Heya 18, I wish they'd churn some more of those OCZ's out myself :)
I want 4Gb more, they'd only let you get 4 ATT :P
Had to back mine down a little to make em Prime stable I guess from the Egg posts.
Anyone notice that the Egg is selling the Trident 1200s for the same price as the Pi 1200s?
just got mine..no go @ 1100mhz 1.85v. needs 1.9v to be stable so far
i'll try to go higher later
My PC is stable @ 1100 1.8v PL6 with all 4 slots running... and I tighted subtimmings. My problem is that they don't go ahead 1100... no matter what timmings / PL / voltage I apply them.
What mobo do you have?
EDIT: I saw on your sig... I also tried these sticks on my dad's P5K premium, and 1100 is the limit...
My OCZ 4 GB DDR2 PC2-8500 Platinum Low Voltage Dual Channel Memory Kit OCZ2P1066LV4GK's come in next week.
Not to tangent too far but I'll post how they perform since they are a cheaper low voltage 2x2gb 1066 kit too.
Edit: Got the set. Here is the cpu-z. Black PCB's and 1110 rating. These stress tested to about 1150 1.8v:
http://i246.photobucket.com/albums/g...at10661110.jpg
1.904v (bios) / 1.82v (everest) running @ PL3 (default)..i try to loosen it up later. i also haven't done stability tests between 1.86 - 1.9v though
i did notice someting..i'm not that familiar with ram stability tests but it did pass memtest @ 1120mhz/1.9v ..but it wouldnt even last 3 minutes in prime95 blend with any voltage below 2.0v
So anyone tried the Trident 9600s?
I have 4GB Gskill Trident 8500
is very good ddr2 :D
i have at 1100mhz at 1.85v
I just ordered Trident 9600s. Should be here Tuesday. Got tired of waiting for OCZs to come back in stock. Sure the Gskills are a cost premium but at least they are available.
Anybody having trouble getting these Tridents (F2-8500CL5D-4GBTD) at stock speeds/voltage on an AMD system? I have a ASRock A780GM-LE/128M (which states it supports 1066) and a Phenom II X2 550BE and can't get them to run at stock 1066 at all. I'm thinking it's the motherboard though.
Maybe you should try this one..
Trident F2-9600CL5D-4GBTD..
1200mhz 5-5-5-15-52 PL 6 @1.81v
http://img32.imageshack.us/img32/150/57272785.jpg
1260mhz 5-5-5-15-52 PL 6 @2.05v
http://img8.imageshack.us/img8/5549/63549610.jpg
Hi, did someone go over 1300mhz with F2-9600CL5D-4GBTD like the 1200 pi kit ?
When i try search in forum for "F2-9600CL5D" it don't give me any matches but somehow i found this thread.
btw This is my first post in XS :wave:
wow 10x for fast reply
Edit:
@ aslanwas thanks ;) i read it already took me lot of time hehe
I've seen talk of over 1300, but never any actual proof.
As the Pi 1200s are ProMOS & scale decently with vDIMM, you can do 1200-1350 from the results i've seen.
These Tridents are almost certainly Elpida (same as the OCZ LV Blades), & you cannot get much past 1200-1275 generally.
