i googled for picopsu and found some interesting things, everything is very small, except the price =P
Great build, I really appreciate this small builds, and the cooler getting air directly from the outside is perfect!
Smallest pc on XS eh?
I bet theres a lot smaller ones based pico-, nano-itx and some smaller. Smallest possible would be around 8x8-9x9cm based to 3x3" beagleboard which have omap3530 arm cpu but still capable for running kernel modified ubuntu linux and other distros too.
I have one little smaller one dimensions: 189mm x 189mm x 65 mm, little wider than yours but smaller in cubic cms :D
http://www.xtremesystems.org/forums/...3&postcount=44 there's couple small ones.
Hmm let's see can i snip couple mms out from my own SFF case :p:
That's pretty cool man :up:
some new pics (poor) but after 100% finish will be better
http://img259.imageshack.us/img259/3440/76912554.jpg
http://img259.imageshack.us/img259/1984/57097728.jpg
http://img259.imageshack.us/img259/994/42109727.jpg
I've heard of two blokes argueing 'mines bigger than yours,' but never 'mines smaller than yours,' before :rofl:
Thats some really nice work there though Duniek.
And those are pretty sweet systems you linked to as well s0lid. I had seen the top one before but the bottom one is awesome.
Hehe here's one pretty small and cool http://metku.net/index.html?path=mod...kypc/index_eng :D
Going to make my case around 180x180x40mm from 5mm plexi glass :P
Thats cool.
My favourite nano itx mod that I ever saw was someone put one inside of a Millenium Falcon action figure.
They put LED's in the :banana::banana::banana::banana:pits and everything it looked amazing I just can't harness the power of google right now to find it.
this is "normal" mini itx
nano itx will be smaller :D
new case incoming
dimension will be about 200x200x85mm
specs: 9300 itx wifi + 2,5" hdd in scythe quiet drive + 2x fans 2x92/2x80 or 2x100
I bought cooler (380gram copper) + made custom enclousure from plexi; total cost 12$ with shippings :D
http://img141.imageshack.us/img141/4332/74304992.jpg
Cool, I wondered how you would set that up :)
I am planning to make new case from copper :D
Realy, realy but realy nice cases :eek:
plan changed :D
case will be from COPPER :eek:
Did somebody say slim mini-itx case :hrhr:
http://www.intel.com/Assets/Image/pr...45GSEJT_lg.jpg
http://www.intel.com/products/deskto...T-overview.htm
At highest point that mobo is only 20mm thick, so if used material is 2mm aluminium, total case thicness would be only around 25-26mm and only around 176x176-8mm long/wide :p:
i have different idea but i think its possible
get pcie ribbon and get a 4770 (only takes 50 watts) lay it flat and then on the zotac 9300 just get q6600 + 8gb/4gb ram in 2 dimms
then a the new 150watt pico psu (2 of them 1 for gpu and 1 for the cpu)
then a slim drive and a 2.5 convential drive on top of the motherboard then simply get the dimmensions and create your own case
the only bad factor is that it will be rather long and maybe a little taller (due to the slim drive)
:hrhr: 4,5kg (200x200x70-80)
yap, but damned 9mm SSD 2,5" thinkess :p:
q66 + gf7300 not work good with FSP 270W PSU
(q66/g31/2gb/2,5" hdd takes on load 130W
on150W psu(8A 12V) not possible
but for itx quad? e7200/e8200 is enough a hell lot for that board + maybe 96/9800gt eco :O
I were thinking of using Mini Pci-E SSD.
http://p.gzhls.at/424496.jpg
http://geizhals.at/eu/a424496.html
new two cases in progress
dimensions will be 190x190x96mm and second 200x200x110(115) but with DVD drive
Will be powered by picopsu 200W, 9300itx, e7200 stock 1,05Vcore, 2x1gb ram, 9600gt LP
I made test of this mobo this evening with E5200 ,1,225V + 0,3V on bios
pushing it to 3,9ghz rock stable cooled by copper heatsink + 92mm fan @ 5V
tempsin HW monitor 79*C, on thermo I saw 48*C max on base of heatsink
http://img199.imageshack.us/img199/8472/tnimg1354.jpg
Where did you get these standoffs? They seem to be much longer than regular ones you get with cases.
they looks like from silverstone my from the tj07 are 1,5cm
great projekt i like it :) are u finished yet ?
