I'll have this guide up when P55 boards hit newegg.
If I don't, spam my PM box :p:
Perkam
Perkam
what about the new amd stuff in october along with 5000 series and gtx 300's will that be up then ?
The new GFX from AMD and P55 will launch around the same time. Nvidia's GTX 300 is a tad later.
Remember that new CPU platforms require new processors, motherboards and sometimes new memory, whereas a new GPU platform is just drag and drop, so these guides are built around newer CPU platforms, not newer GPU platforms.
Perkam
It's coming VERY soon :)
Perkam
woooot
Done.
Intel Sub-$600 System
Intel Pentium Dual-Core E5400 Wolfdale 2.7GHz
I would get Intel Pentium E6300 Wolfdale 2.8GHz @$84
Typo :)
Intel Sub-$1,100 System
Intel Core i5 860 Lynnfield 2.8GHz
Intel Sub-$1,700 System
Perkam can you please tell me where I can get those 5870 Radeons please? :p: BTW how did you know they are 512bit?
AMD system for over 2k ;)
Are you sure?:DQuote:
XFX HD 5870 1GB 512-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported - $299
Ignore me, didnt see the shipping cost:am:
Great guides ill be sure and use these to help me build my next gaming rig :)
Gotta wait till Call of Pripyat comes out first though :p
@ OTH, E5400 > E6300 in highest OC.
@ 5870 = Estimate based on 4870 Launch.
@ SSD, G1 = tried and tested. G2 has problems now and may have problems down the road. It's definitely a pick for 2010, not 2009, but I might change on this, who knows.
Perkam
Just put this together for under $1000, you may be able to save a few extra $ buy using the newegg combo deals. One I noticed gives you the Case with a 350W PSU at only $10 more then the case on its own.
But for under a $1000 it makes a good everyday system, you may want to stretch to a Q9400 or even a Q9550.
Intel Core 2 Quad Q8400 Yorkfield 2.66GHz LGA 775 95W Quad-Core Processor Model BX80580Q8400 - Retail $169.99
Western Digital Caviar Blue WD6400AAKS 640GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM $69.99
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM $74.99
Antec earthwatts EA380 380W Continuous Power ATX12V v2.0 80 PLUS $49.99
GIGABYTE GA-EP43-UD3L LGA 775 Intel P43 ATX Intel Motherboard - Retail $79.99
SAPPHIRE 100265HDMI Radeon HD 4830 512MB 256-bit $94.99
COOLER MASTER Elite RC-332-KKN1-GP Black SECC ATX Mid Tower Computer Case - Retail $49.99
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL4D-4GBPK - Retail $54.99
SAMSUNG DVD Burner Black SATA Model SH-S223L LightScribe Support - OEM $28.99
BenQ G2410HD Glossy Black 23.6" 5ms, 2ms(GTG) Widescreen LCD Monitor - Retail $229.99
Rapoo Wireless Keyboard&Mouse BestBuy $15.00
$918.90
Since 775 is going to be around for a couple of years to come there is still plenty of life left in Intel CPUs and Motherboards. When you consider there is a 24inch HD LCD in the package its not bad for the $.
Nice list sir
XS Official Rig Building Guide UK Edition, Europe Edition and Canadian Edition are on their way...
Perkam
Here's the fastest gaming system for $800! This system is identical to the one on the first page (which I suspect is slightly outdated), but has a 4890 instead of a 4850. For $800 you want a 4870 at least! Of course I was only able to achieve this through the use of sales and rebates, but those are always available one way or another.
Intel Core i5 750 Lynnfield 2.66GHz 180 @ microcenter
GIGABYTE GA-P55M-UD2 LGA 1156 Intel P55 110
OCZ Gold 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 90
MSI R4890 Cyclone OC Radeon HD 4890 1GB194 @ ZZF with an extra $20 MIR
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 65 @ newegg
HP Black 24X DVD+R 31 @ newegg
Antec Three Hundred Black 55 @ newegg
OCZ ModXStream Pro OCZ600MXSP 600W 80 with an extra $25 MIR
Total: 805 including shipping (all items are in stock and have free shipping!) Also has $45 in MIRs which brings the actual total down to 760 after MIR.
Once the MIRs come in, that leaves you with $40 to put towards a CPU cooler (once they are more available for LGA 1156). When overclocked, the core i5 should be faster than any other CPU. This 4890 has better cooling than the reference model - Anandtech found an overclocked 4890 beats a GTX 285@stock on almost every test.
Here's the performance you can expect from this 4890-based system after overclocking. Pretty sure it's an i7@3.2ghz with intel SSD.
http://images.anandtech.com/graphs/4...2109/18843.pnghttp://images.anandtech.com/graphs/4...2109/18845.png
http://images.anandtech.com/graphs/4...2109/18830.pnghttp://images.anandtech.com/graphs/4...2109/18828.png
All for under $800!
i5 has obsoleted LGA775 and AMD completely.
Fixing the list...
Just waiting for 57xx cards to come out. Then quite a few updates come in, including $99 quad cores from AMD.
Perkam
i would recommend this memory for the 1366 platform
http://www.xtremesystems.org/forums/...d.php?t=235587
btw dont forget to update the 5870 prices :p:
edit: i cant see any reason to recommend the g1 version of the x25-m over the g2 anymore :shrug:
October 2009 Update Complete.
Let me know if there are any errors.
Perkam
The i7 860 is written in as i5 860. OTH mentioned it above.:)
Fixed, ty :)
Perkam
Sorry why different cases for Intel and Amd?
