iometer 100% seq read and write for 8x16gb mtron SSD on HPT 3520 -
performance test just doesn't test your system correctly. Neither does crystalmark it seems... Just shows further that there aren't any decent benchmarking programs for SSDs at this point :(. Except for IOMeter of course :D Kind of odd though because everything was in unison for me and all benchies seemed to work right.
You have posted the wrong graph. It is about 400-500% better (not 50% better) at equivalent 64k block size
It really depends on what scenario, what apps you are using and how they are being used
Remember those results are single drive results, on the same controller. How they scale with different controllers is a whole other topic :)
Hi,
Do you have your OS installed on the mtron array? If not, have you tried? I have the Rocketraid 3510 and 4 OCZ SSDs and the ga-ex58-ud5 motherboard and can't see the card in the motherboard's BIOS. If you do have an OS installed, can you tell me any and all settings or procedures you followed that might be relevant to me?
thanks
heres 4 intel x-25e"s on the rr 3520 controller..what do u guys think as a comparison.
Good morning,
I have the ggbt extreme but pretty much the same as the UD5 - I have had no problem booting from the array when it was attached to my extreme.
I am currently using my 3520 on a different machine though.
I have used the 3520 on at leat 3 different mobo's and not had any problem like what you are describing.
Did you try different ggbt mobo bios?
Make sure you have the latest firmware loaded on the 3510.
Also - not sure but it might be that you need to have at least one drive set up on the 3510 for the bios to recognize the drive connected through the 3510.
Woooa!
You should do IOmeter full test and 4k read/write test from OCZ so we can see how it blowz the Zdrive away :D
