yea HT enabled.
DOE you lost a DDC3.2?
can you open it up and see if it shorted?
i'll open it up when i get the new one, field work is just tiring..
oh yeah ek supreme is bowed...i just found out, which explains why my mounting temps were really close to another..but the bowedness(is that a word) around the outside of the base...
can anybody confirm the bow is circular? the gtz i think is cylindrically(is this a word) bowed
Hell of a block... but isn't cheap. Having machined *tiny* electromechanical parts for more than a decade I must say the quality of the work on the bases is quite impressive though.
gtz cylindrical, because inner square frame has to "humps" top and bottom to bow the base...
So itīs the D-tek the better choice for I7 today ?
i don't have the mounting bracket yet...hopefully they do get out with one...
man...
I currently have D-tek Fuzion V1 and not sure if I should get GTZ or Koolance 350:shrug:
BTW, D-tek guys must be upto something in their labs to miss this oppertunity to add just a simple mounting bracket... :rolleyes:
This is my block XSPC Delta V3
enjoy
crypto
nice results..whats your loop components? pump rad etc?
im idling at 32-32-35-34 with the k350
Any of you water-cooling experts have thoughts on the XPSC Delta block for Nehalem?
lofunny u ask these is my system
I7 920,
Evga X58, soon Evga X58 Classified
Mushkin XP3-12800 Triple Channel Memory Kit
Evga 8800 GTS 512 SLI, soon Evga GTX295 + SLI
Evga GTX260 216 SSc 55Nm
WD Black 640 Raid 0
Seagate 500GB x2 Raid 0
LG GBW-H20L Blu-Ray Burner
Samsung SH-S223Q/BEBN
HT Omega Stricker 7.1,
G15 / MS SideWinder
HP w2207H HDMI Monitor
XSPC Delta CPU V3 I7 Bracket
XSPC Acrylic Reservoir for Laing DDC
Thermochill PA 120.3
CoolMaster HAF 932 Top mount Rad Mod. PUSH and PULL
Corsair HX1000W
Windows 7 Beta 1 X86
Ohhh!!! Finger lickin' good! No good without OC and temp info, though. May I haz pleeeeze? :D
thats idle.
idle doesnt prove anything.
Load her on OCCT or Linpack.
Also you didnt state ambients.
What ambients are you running?
THe XSPC block is a great block, its a low restriction block which means it will do better on multi block setups.
But it will get its ass handed by a GTZ, KL-350 and a pressure pump system on its own loop.
u think that was idel lol i was 2 hrs of prime buddy and as far as ambients is there a program to use for ambients
no bud this is idle.
And excuse me, a program to find ambients? Its called a thermometer at your intake.
Post one of these with realtemp on at the start of your test so we can see your MAX temp:
Oh and realtemp has a timer too BTW.
http://i125.photobucket.com/albums/p...la/Linpack.jpg
Or this is fine with 10min into it:
http://i125.photobucket.com/albums/p.../OCCTFinal.jpg
Yes, by 1-2C. Honda quadruple confirmed it for me.
Here a little GTZ mountplate modd to make it fit the D-tek Fuzion v1. Needs a little more adjustment but i hope it works :)
http://img152.imageshack.us/img152/5...1421na9.th.jpg
What exactly did you have to mod?
That is some fine fine chip you go there.:up:
What batch# is it ?
Mine requires 1.425v to run @ 4200Mhz with HT=ON.
Temps are nice, about 73c for the max core with LinX .0.5.5.
BTW, Linpack only use 50% of the CPU if your HT is on, make sure to use LinX 0.5.5 if you want to get 100% Load on the CPU with HT=ON.
