:woot:That board appears to be Nforce free.:woot:
All first release Nehalem boards will most likely be as their design was most likely finished before that. Don't count on that for the later releases though :P
Wonder if that will mean there will be some dual CPU enthusiast level boards from other board makers now since the main chipset is also the dual CPU capable server one.
I'll just wait for ASUS ROG series :yepp:
And yes, that's not odd if X58 has SAS ...
Are the ROG boards really better? Always seemed kind of like a scam :P their normal boards seemed to have the same features, the ROG ones usually just came with flashier packaging and some kind of sound card you wouldnt wanna use anyways if you were gonna go with an add on card.
Does the SAS support really not support Raid 0 or 1? if so thats kind of lame.
ROG generally has better OC performance. I still like the ROG features ... :up:
SAS should be RAID supported ... That's according to m/b manufacture to add up an SAS feature or not. Our mobo(more bigger than P6T :ROTF:) doesn't add the SAS chipset, but the layout is ready to adds optional SAS feature if needed :)
Think this chipset will promote more mobo manufactures to make a Dual CPU Enthusiast grade board now that the Server dual CPU capable chipset is the same as the high end enthusiast one is?
HOLY CRAP!!!
16 phase!!!! and i bet this thing is 8 layers,
this is going to be the most expensive mobo EVER
why is the picture watermarked with ocxtreme and awardfabrik?
this picture is from pcdvd in china, so somebody copied it and then watermarked it? :P
Lets just hope that these will be better boards than P5Q3's.
Mmmmm, capacitors shoved right up next to the socket.
Perfect for insulating......... :(
http://www.pcdvd.com.tw/showthread.php?t=808969
heres the original pic from pcdvd:
http://www.abload.de/thumb/001-186lp8.jpg
A bit OT saaya, but are you some kind of nomad? It seems that you show up all over the world, you are now in Taipei.....
Must be great though, I wouldn't mind having to travel that much :D.
next week Asus has official Nehalem day in Berlin, they will introduce complete Nehalem boards ...
