Yes, if the voltage is able to go up to the max of 1.327v set in bios then you could get the core upto around 850mhz.
With just a bios flash.... wow....
Now I really really need to read up on it. Do I need a multimeter for a bios flash like I need for a pencil mod or volt mod? Because I don't have one on hand.
To be honest I don't know if the 1.327v bios mod actually works, my cards are hard modded so you'll have to waite for Leonarderman to chime in.
Oh, it kind of sounds too easy to be true :/
oh, so is it not worth doing a bios mod?
Ok, what I will do is OC as high as I can with no mod's. I need to be told how to do the rest of this stuff afterwards though :P
http://www.xtremesystems.org/forums/...68#post3195868
Could you help me out please?
Please note: Don't try to use Pencil mod if you don't have a better cooler (Water cooling is best for use). Because pencil mod can give vcore 1,4V - it'll make your HD4850 card too hot. I tried with my Sapphire HD4850 Toxic + Zalman VF900, it's so hot that I can't Overclock GPU core more than 815MHz.
Here's your HIS HD4850 Bios file: HIS HD4850 Bios ModdedQuote:
leonarderman, do you think you could mod my HIS bios? I have it linked in a post at the beginning of page 2.
Thanks.
Core Upper limit 800MHz
Mem upper limit 1300MHz
Here's your Diamond HD4850 Bios file: HIS HD4850 Bios ModdedQuote:
Can you mod my original bios and change only the upper limits please? DiamondHD4850.bin
Core Upper limit 950MHz
Mem upper limit 1400MHz
Thanks bro.
You should create an USB Bootable to Dos. You can make it from the guide here:
http://www.thepcspy.com/read/bootable_usb_flash_drive
Then you have to copy ATIFlash programs 3.6 (download below) or newer (Dos) and Bios file to USB Disk. Try it done! :D
http://www.techpowerup.com/downloads...lash_3.60.html
Please note: Updating by ATIFlash 3.6 or newer (Dos), don't try to use ATI WinFlash, because I found the problem from bios file maked by RBE1.12 - ATI Winflash can't open bios file maked by RBE1.12! :)
Please, do one for MSI HD4850 also :)
leonarderman
May be You can write "How to" with pictures for All, pls
yes, i'm do it. I convert in calcularor 70000 (Dec)-> 11170 (Hex)
open bios in winhex end find hex value 701101 - i'm find a value
edit 701101 (700MHz) -> 187301 (950MHz), check checksum and save bios
RBE say what clock upper limit set to 950MHz :rehab: :rehab: :rehab:
i'm flashing the bios nice, but catalist 8.8 don'd work with bios :down:
Why so many different limits and versions?
Just open them up to a high value (1200 core+) but leave the volts/clocks at default.
Your MSI Bios modded here
Core upper limit 950Mhz
And I don't change anything else! :D
@ STEvil : do you thing you can overclock GPU HD4800 more than 1200MHz? The WR is 1050MHz with hard modded! I thing 950Mhz are enough! :D
Catalist 8.7:
http://images.people.overclockers.ru/preview/162441.jpg
I think my S1 + 120mm fan should be enough to get me a decent overclock.
can some1 link me to the pencil mod?
It can be found here!
http://www.techpowerup.com/articles/...g/voltmods/151
@ STEvil: That's so good! Try to top WR. Good luck! :D
I could just overclock my to 815MHz with pencil Vcore modded. The card is so hot that I couldnot overclock more than that! Here is my result 3DMark Vantage Performace.
http://thienloipc.com/leonarderman/s...vantageoc3.jpg
Thanks man, you used your bios mod + your pencil mod right?
