Boy i did i pull a BONER!
temp test went as follows ; Blower on at all times
rad #1 house hot water inlet temp 120F outlet temp 98F air temp 72F
rad #2 inlet temp 120F outlet temp 102 air temp 75F
then was dis-assembling the test hose & this happened went to remove the temp tubing setup & was useing sissors (I know 1st dumb thing it did) to cut off the tubing on the barbs > stabbed the rad "Holey S**T " but it looked as if i missed the tubes just fin damage
SOO I ran house water thru unrestricked & counldn't tell for sure if it was leaking
SOO >>> I think >> I'll plug the outlet & then I'll know for sure . Soo I hook it all up & place a plug on the outlet hose Then I run in the house turn the water back on >> by the time i got 1/2 WAY back i could hear the fins popping ..
>>Everyone Laff now ! >>
>> GTXBlkIce 480 shot to Sh**
it is now > leaking ... but NOT at the site of the damage !
link to the post I did with the pix of damage ....>>>>> http://www.xtremesystems.org/forums/...d.php?t=187491
OH well $140 down the toilet & a valuable lesson learned
NOTE to myself Never agin test anything & I do mean anything on house water pressure !
