What was the frequency limit on the 3850's?
Just need FLASH TOOL.
whats goin on with the bios????
cant wait to update the bios... come on give us that tool man...... ;)
the flashing utilities in our download section dont work with rv670 .. but i'm working on getting those tools
Nice :) Thank you!
@w1zzard
:up:
I hope amd/ati continue on this path with o.c. working on both cards from the release, and quick bios fix like this... to reward their hard work I am going to buy a couple. heck ,I may get three for tri-fire.
I need this flash tool quick :D
Waiting since yesterday for that.
Same here, and under 41C load @860MHz with my Accelero S1 + 140mm Yate. I think this chip has a ton of headroom. Trying to be patient, but that bios is just there mocking us :ROTF:
Well either way, ill be away for the next 2 days for Thanksgiving holiday, so hopefully that will take my mind off this until the weekend
Hmmmm... I coulda swore I reposted it. Oh well.
Thanks Jup.
Hopefully the His or Sapphire cards come back in stock sometime soon, when I'm not working, so I can grab one.
Excited to see how far these can be pushed on a chilled H2O setup or for those crazys that work with DICE.
Anyone know if a 600W PSU will power two hd3870's in xfire? its coupled with an x2 6000+, 1 360GB hdd, 2 DVD drives????
And how does the S1 sit with the stock ramsinks?
A solid 600W will be fine since these do not suck nearly as much power as the 2900XTs. I highly recommend the Corsair 620HX if you are looking for a very solid / modular 600W supply. One gigantic +12v line and it wont flinch even with quadcore systems
The S1 clears the Stock Ramsinks fine. I kept all the sinks (memory, vreg) except for the main gpu hs. The biggest drawback is you won't be able to use the cooler in a crossfire setup since its wayy too big and blocking the connectors. I wrote up a mini-review if you are interested in seeing the temps I am getting with the S1. http://www.xtremesystems.org/forums/...d.php?t=166432
I'm running on 600W OCZ SXS and slightly overclocked 6000+. On top of that 400GB Samsung, 2x40GB IBMs, SB Audigy, 4 fans, card reader, DVD RW, so on...
All that when OCed can pull 470W max under heavy load. Mind that CPU @3500 1.5V, mem @2.32V, both cards @860/2400!!
Hope that this will help... :up:
Pro....
Thanks v.much i shall definitely bare that in mind :D
Another question if you dont mind :D i'm just trying to decide what kit i need for upgrade to crossfire 3870's, do you reckon i should go for:
MSI K9A Platinum Crossfire (Socket AM2) PCI-Express DDR2 Motherboard
http://www.overclockers.co.uk/showpr...d=5&subcat=808
or...
Asus M2R32-MVP Crossfire (Socket AM2) PCI-Express DDR2 Motherboard
Thanks in advance :)
eh should u be getting the 790 mobo instead??
the
MSI K9A2 CF AMD 790X (Socket AM2) PCI-Express DDR2 Motherboard
- AMD® Phenom/Athlon/Sempron CPU.
- HyperTransport 3.0 supporting speed up to 2600MHz
- AM2 CPU supports HyperTransport 1.0
- AM2+ CPU supports HyperTransport 3.0
- AMD® 790X and SB600 Chipset
- Supports Dual DDR II 533/667/800
- 1x PCI Express x16 slot with x16 operation
- 1x PCI Express x16 slot with x8 operation
Just assumed it would be better to get a gfx with full bandwidth on the PCI-E??
OH and everybody, go to
http://www.techpowerup.com/downloads..._Flashing/ATI/
theyve put new versions up :D:D
