Originally Posted by
NaeKuh
ranker, id be very very careful about that rear PA. I noticed really quickly that i couldnt do a push/pull config on my MCR220. If i also recall correctly, a PA +120mm fans = MCR220 + push/pull fan config in size.
In other words, You might not be able to fit it because your hard drives will cram up hella close to your 5 1/4 bay. Or worse case scenario, you'll only be able to mount 2 hard drives at the lower section.
Yeah, i wanted push/pull config on my MCR220, but, as i said, i had to improve a lot when building her.
