If Yoxxy's right there is no throttling at 85C if coretemp is to be believed. What a way to prove a point killing a 6300, but throttling started at coretemp = 100C and the IHS measured 83C. Its know from IHS removal attemps, that the solder on the core melts anywhere from 77C to 85C. Even if the temperatures are taken from the core, throttling has to be lower than at most 85C.
The other thing that makes me think is the idle temps. I've two idles to choose from:
http://img169.imageshack.us/img169/3953/tempshp0.th.jpg
My HSF-Tuniq has an approx thermal resistance of TR=0.18 C/W including some losses. Just using the simplified dissipation equations:
If it idles at 31C (20C ambient) according to ProbeII/Speedfan = 61W
If it idles at 46C (20C ambient) according to coretemp = 144W
Which one is more likely for an idle C2D at 3.6GHz/1.48V?
REF TDP is 65W.
TR = RJC + RCS + RSA
Tj = Ta + Pt*TR
where:
TR = Total Thermal Resistance
Tj = junction temperature (or cpu temp)
Ta = ambient temperature
Pt = total power dissipation
RJC = thermal resistance, junction-to-case, = 0 for this.
RCS = thermal resistance, case-to-sink, = 0.0045 for AS5
RSA = thermal resistance, sink-to-ambient = 0.1775
