but the Retails need unnormal Voltages for these Clocks ...
not 1,55 like ES on Water but 1,65 on SS
looks like retail got same problem as merom/yonah, fsb limited bij cpu :(
no, it is not a FSB limiation, the Retails are simple bad to overclock my E6600 runs atm @ 3,7 by 1,54 V ... PrimeStable
Explain my situation then if it's not a FSB limitationQuote:
Originally Posted by Kabauterman
Max. benchable FSB @ boxed air: 455x6
Max. benchable FSB @ SS: 485x6
Max benchable CPU @ boxed air: 3708MHz
Max benchable CPU @ SS: 4357MHz (mobo limited)
Looks like FSB limitation to me...
but it is a Mobo FSB limitation not a CPU FSB Wall like Yonahs
Why does misteroadster run 566x9 with stock vMCH with the same board?Quote:
I tried almost every setting to go past that 485 wall with SS but non worked. Even the settings from VictorWang didn't made a change.
But I'm pretty sure that my mobo will go past 500MHz FSB with a 2MB CPU or a 4MB ES.
I think the CPU isn't the limiting factor ... in some German Forums are Lists with Max FSb on P5WDH
http://www.forumdeluxx.de/forum/showthread.php?t=256507
Nice .....but last 5 post where talking about the asus p5b so that's isn't the issue here :stick:Quote:
accually we should test it by putting my retail in rol-co's board.
say its more like tis ;) .
975X is good for retail with 4MB
965 is good for retail 2MB
965 with 4MB retails = big problems
but ES seems to not have any problems with the bords ;)
Originally Posted by blind_ripper
but not the P5WDH without Mods ...
No mods, no fun ;)Quote:
can i get stable @ 3,5ghz with retail 4mb & 975x (no mod) by air?Quote:
cause my E6600 haven't arrived yet :(
:stick: i cant look in to the futeur :DQuote:
Originally Posted by jozzy
M.Beier is right :p: no mods no fun .
yep,......easy, thats "only" 388 fsb, 400 must be no problem for this combination without mod'sQuote:
Not true, I had a lot of fun with DFI NF4/Expert without a single hardware mod :D
The best board is the one that does not require a single hardware mod for extreme oc :)
And I sincerely hope there will be such board for Conroe :)
Hi~ :) Rol-Co
VMCH 2.3V Is possible?
In my case, freezing Window(2.12V Higher set)
To inform a method :D
i think my is the absolutly :banana::banana::banana::banana:ing P5WDH on the world ...Quote:
Originally Posted by M.Beier
FSB 395 without Mods (vMCH 1,65V)
FSB 425 with !!! 1,95 V !!! Stable :eek: that is so bad ...
2,3 and up is possible , but only with pci graka, pci-e goes black above 2.15 or freez up indeedQuote:
Originally Posted by OC_Windforce
pci-e boot @ 1.84 and when the screen goes on set the voltage to 2.08 ,with this way 3d is possible
every reboot the same way
pci doesn't matter up to 2,45v :D
Originally Posted by Rol-Co
oh~! PCI graka :woot:
Very Thanks :slap:
In my case (NB Water Cooling)
-> http://www.xtremesystems.org/forums/...d.php?t=112001
same here , chilled water
32m 500fsb done on air.....:D
oh~ same chilled water :)
Became the help where you writing is many.
Wow~! Good Result(32m 500fsb done on air.)
I'm Korean.
It very like the Guus Hiddink football supervision of you country. :D :D
And he is the hero of my country..
I have decidet to buy me a DQ6, the P5WDH is a nice Board but it's need to much vMCH to get High FSBs
or the p5b , is a nice board tooQuote:
but 12phases are very nice ...
