Link to results, or just speculation?
Why ? You simply assume AMD will pull a 3.4GHz DC out of its basement just like that ?Quote:
Originally Posted by M.Beier
Frankly I would be surprised if they will match the 90nm speed in the 1st few months of 2007 until yields ramp up and the process matures.
First of all even with less scaling factor Conroe will beat AMD on 64 bit clock-to-clock:Quote:
Originally Posted by duploxxx
http://www.xtremesystems.org/forums/...d.php?t=101497
FX-62 3GHz
1 CPU 422*1.31 = 553
Conroe 2.7GHz
1 CPU 469*1.18 = 553
The second thing is scaling factor which depends on the used aplication. For example context C4D Shading (form Cinebench 2003) (32bit->64bit):
K8 +3-4%
http://www.xtremesystems.org/forums/...46&postcount=1
Conroe +17-18%
http://www.xtremesystems.org/forums/...83&postcount=1
Have you seen swordfish??? - Well, when the hacker got 1 min to get into pentagon, he gets a special service... - Anyhow, THAT I need WHILE benching the gear :DQuote:
Originally Posted by IvanAndreevich
I wouold like to see a cinebench cpu render test comparison when these two cpus are at their max air cooling oc
Originally Posted by kl0012
ehh nice try, calculate again thast 30% not 3%...:cool:
and the other benches, thats 32 bit, yes conroe has better clock performance... try this again on 64bit
Where exactly I did be wrong?Quote:
