Yeh man... Im really reconsidering...
Thanks alot... REALLY!!!!
I Like that D-Tek Fusion Block...
Pitty D-Tek dont have an all in one 3850
For now Im considering going EK
With a EK-Supreme - Acetal...
With a EK-FC3850 CF Acetal (2nd one later when I get an additional HD3850)...
And a EK-NB4 intel - Acetal...
What Im planning to do.
Ive got a CM Stacker 830
Im planning to mount 3 RADS...
Dual RAD under the top fan oppening...
Single RAD at the back fan oppening...
And a Tripple Rad mounted under the case (Will have to cut out section)
Then having a single loop system with each RAD between Blocks (RAD Block RAD Block RAD Block)
Obviously Id need a pretty strong pump, so im still looking for something.
Now I know this might sound Over Kill... But I like Over Kill.
Im also planning on placing a 288 Watt TEC attached to the loop with an additional block to chill the liquid passing though. The TEC will be cooled with a CM Geminni Fan Cooler.
I will have to carefully plan this whole thing since I have 8 HDD's and with me DVD writer completely fills up my Drive bays, so i wont have space to hide pumps and so on in there. Im a bit of a neat freak... so Ill have to do it really nicely.
This guy is doing something similar to what I want to do.
http://www.xtremesystems.org/forums/...d.php?t=178079
