First time with semi serious OC on air
I have the EP45-UD3P with the E8400.
The CPU-Z reads different than my bios cpu frequency???? Which one is correct? I have bios 11c and CPU-Z version 1.56.
I am a total noobe even though I have been reading a lot on this site for a few years.
Any advice greatly appreciated. I copied the following setup in the bios from radaja's recommendation. THANKS!!!!
Code:
E8500 500x8@ 4000MHz F10 BIOS
Robust Graphics Booster.........................[ Auto ]
CPU Clock Ratio.................................[ 8 ]
Fine CPU Clock Ratio............................[ 0 ]
CPU Frequency 4.0GHz...........................[ 500 x 8 ]@4000
******Clock Chip Control******
CPU Host Clock Control..........................[ Enabled ]
CPU Host Frequency (Mhz)........................[ 500]
PCI Express Frequency (Mhz).....................[ 101 ]
C.I.A 2 ..................................................[Disabled]
******DRAM Performance Control******
Performance Enhance .............................[Turbo]
Extreme Memory Profile (XMP)....................[ disable ] disable this before you try setting stuff,otherwise it wil reset things
(G) MCH Frequency Latch.........................[ 400MHz ]
System Memory Multipler.........................[ 2.00D ]
Memory Frequency 800...........................[ 1000 ]
DRAM Timing Selectable..........................[ Manual ]
CAS Latency Time 4................................[ 6 ]
tRCD 4............................................[ 6 ]
tRP 4.............................................[ 6 ]
tRAS 12............................................[ 15 ]
******Motherboard Voltage Control******
Load-Line Calibration [Enabled]
CPU Vcore [ 1.25 ]...................[ 1.400 ]
CPU Termination [ 1.20 ]...................[ 1.28v ]
CPU PLL [ 1.50 ]...................[ 1.57 ]
CPU Reference [ 0.760 ]...................[ Normal ]
MCH Core [1.1 ]...................[ 1.380 ]
MCH Reference [0.760 ]...................[ 0.73v]
MCH/DRAM Refernce [0.900 ]...................[ Normal ]
ICH I/O [1.500 ]...................[ Normal]
ICH Core [1.100 ]...................[ Normal ]
DRAM Voltage [1.800 ]...................[ 2.00v] try 1.98v to 2.00v for 1000MHz
DRAM Termination [0.900 ]...................[ Normal]
Channel A Ref [0.900 ]...................[ Normal ]
Channel B Ref [0.900 ]...................[ Normal ]
