http://img8.imageshack.us/img8/1195/mystats4p.th.jpg
For some reason my processor is running a different multiplier on 2 of my cores then on the other two of my Q9450 quad core. I turned off both EIST and C1E but some programs are showing that they're still enabled, so it seems that I may need to flash my bios. I'm using Bios ID 14 currently which came out before the penryn 45nm cpus were released but I didn't appear to have any compatibility problems with my system until I noticed this difference in the multipliers. Which BIOS would you guys recommend for the Q9450 16,17 or the beta 18? I bought this motherboard and cpu as part of a system so I've never flashed a bios before. I can flash from a cd-rom right? the abit guide only shows how to do it from floppy and the one on this site only shows floppy or USB just making sure. I've read that BIOS 17 and 18 don't work at all with a USB keyboard not even the del key so the only way to get into BIOS is with a PS/2 keyboard for these BIOS? My USB only had limited functioning with 14 BIOS but then I changed the use keyboard via setting from O/S to BIOS in the USB Fuctions and now the USB keyboard has full functioning is it the same with the other BIOS or is it totally broken?
And just double checking the ccmos switch on the back of the motherboard is the same as the ccmos jumper right? just makes it more accessible right? I really don't want to screw this up
One more question, can I just copy and paste the Bios flash files onto a black cd-r then boot from cd-rom? It won't work will it I need to format it for MSDOS right. Can anyone tell me exactly how to do it I'm getting confused I search on how to do it but there seems to be a lot of ways to make an MSDOS startup CD like this el torito I'm reading about but I need a harddrive under 650mb so I can't use that method. I don't have a floppy drive unfortunately
