use v2.29ES
ASUS Rampage Formula x38 Special Edition
Intel E8400 C0 (Scythe Infinity 1x 120, 1x 80 push, 1x 80 pull)
4x1 GB OCZ FlexXLC 800MHz CL3
High-end Air cooling (5x 80mm fans)
CPU: 9*475 = 4.30GHz
RAM: CL5-5-5-15-auto's
Boots: BSOD @ Windows Vista x64 load
CPU: 9*465 = 4.20GHz
RAM: 931MHz CL5
Boots: Windows Vista x64
Prime / OCCT: Unstable (near-instant crash)
CPU: 9*450 = 4.06GHz
RAM: 900MHz CL5
Prime / OCCT: Unstable (Prime: 1st Thread near-instant, OCCT after 10 secs)
I need some help here >.>
Settings:
Ai OC Tuner: Manual
OC From CPU: Auto
CPU Ratio: 9.0x
FSB Strap: 400
FSB: 450 (at best around 9*500, but I don't think a C0 can do that on high-end air cooling)
PCIE: 110
DRAM: 900+ (FSB500 does 1000MHz is possible stable max pretty sure)
CommandR: 2N
CLK Skew A: Auto
CLK Skew B: Auto
DRam Timing: Man
5-5-5-15 rest Auto
DRAM Static Read: Disabled
Ai Clock TwisteR: Auto
Ai Trans. Booster: Auto
CPU Volt: 1.45
CPU PPL: 1.54
NBv: 1.61
DRAM: 2.30 (+1.0 Overvolt afaik, 2.4v = rated)
FSB Term: 1.54
SB: 1.050
SB1.5: 1.50
Loadline: Enabled
CPU GTL: 0.63x
NB GTL: 0.67x
DRAM Contr: DDR2_REF
DRAM Ch A/B: Auto
Spread spectra: Disabled
Only report I get from OCCT is the CPU Temp going up to near 60 degrees in no time, they seem to remain steady around that temperature though (not sure).
Update: 9*400 (everything on Auto) results in max 46 degrees and even then it's unstable.. OCCT Crashed Code 1
Setup defauls = stable
Any help is much appreciated.
Note: Running latest Rampage Formula: 0410
Made batch command files for easier crossflashing if anyone's interested, just load onto your flashstick and type Max2Ramp or Ramp2Max as you wish. Latest 1207 and 0410 included.
http://www.4shared.com/file/69814588...rified=8f46ec6
I just did the Max2Ramp without issues, have not tried the Ramp2Max flashback though so YMMV.
HTH.
Allubz
try relax lat of your memorys, much voltage :shocked:
Transaction Booster [Disable] [4], less better memory and lat :)
Lats
5
5
5
15 or 18
in my PC I'm using this:
PCI-E Frequency:100
DRAM Frequency: DDR2- 900
DRAM Command Rate : 2
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime :15
RAS# to RAS# Delay : [AUTO]
Row Refresh Cycle Time : [AUTO]
Write Recovery Time : [AUTO]
Read to Precharge Time : [AUTO]
Read to Write Delay (S/D) : [AUTO]
Write to Read Delay (S) : [AUTO]
Write to Read Delay (D) : [AUTO]
Read to Read Delay (S) : [AUTO]
Read to Read Delay (D) : [AUTO]
Write to Write Delay (S) : [AUTO]
Write to Write Delay (D) : [AUTO]
DRAM Static Read Control: [Enabled]
Ai Clock Twister : [AUTO]
Transaction Booster : [DISABLED] [1]
CPU Voltage : 1.4475 Vroop:1.424
CPU PLL Voltage :
North Bridge Voltage :
DRAM Voltage : 2.02 Droop+=2.11~2.13
Using 4X1Gb=2X1Gb Cosair XMS2-6400C4 and 2X1GbSupertalent 6400
1000 @5-5-5-18 2.1 Bios ~ 2.22 windows works fine too :up:
Alright, I tried following, after double/triple reading the Anandtech article and the starting post:
8,5*450 seems to OCCT fine
9*450 wont.
Settings:
Ai OC Tuner: Manual
OC From CPU: Auto
CPU Ratio: 9.0x
FSB Strap: 400
FSB: 450
PCIE: 110
DRAM: 900
CommandR: 2N
CLK Skew A: Auto
CLK Skew B: Auto
DRam Timing: Man
5-5-5-15 rest Auto
Ai Clock TwisteR: Strong
CPU Volt: 1.45
CPU PPL: Auto
NBv: 1.61
DRAM: 2.20
FSB Term: 1.54
SB: 1.050
SB1.5: 1.50
Loadline: Enabled
CPU GTL: 0.63x
NB GTL: 0.67x
DRAM Ch A/B: Auto
Any help appreciated..!
Man, been awhile since I posted in here. I got myself an E8600 and a Tpower I45 board. Put everything together and went to OC. Long story short, I have put this board back in and am clocking the 8600 on it. That Tpower may be good for extreme FSB speeds, but man it is a real whore to get working correctly. Once you have the feature set of an ASUS BIOS, you want nothing else. My board is modded to a Rampage on BIOS 0410 and it just loves this 45nm chip. I am still trying to find the max clock I can reach on water right now, but needless to say the performance has been wonderful. Lesson learned here: You get what you pay for.
i was close to getting one of those too.. i held out after looking at the bios and reading others issues with it.. i am kind of used to this maximus bios. the rampage bios was pretty sweet on it but started to go haywire after a week. it was doing all kinds of funky things with my usb, it would work and it wouldn't. it was also upping my volts to crazy high volts after i would set them where i wanted them.. so i switched back to the maximus bios and havn't had to many problems with it. these asus bios options once you figure them out are pretty friendly. i came from a socket A board so everything was new to me and it took a while. i don't think i would want anything different now after getting used to it.
Well im currently trying to get my system stable at 2.82ghz. I have a rampage formula x48, q9550. I had a stable 2.6ghz setup but im trying for some more now just to see what I can get. Heres a ss of everest
http://i69.photobucket.com/albums/i70/michowski/28.jpg
http://i69.photobucket.com/albums/i7...owski/cpuz.jpg
I cant even run occt. I either get a code 1 error or code 4. Any suggestions to try and get this stable?
Bios are as follow
cpu- 1.33125V
cpu Pll- 1.5v
NB- 1.43v
Ram- 2.00v
fsb- 1.36v
sb- 1.050v
sb 1.5- 1.5v
what does the codes mean from occt?
I uploaded the vid to youtube of my xtreme tweaker section. http://www.youtube.com/watch?v=Cxz_g9R1eCI
try this, if it passes up FSB to 450 and up vcore a few notches, FSBT might have to be raised to 1.30 or so, LMK how it works out
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 8.5
FSB Frequency : 425
PCI-E Frequency: 110
DRAM Frequency: DDR2-1021
CLOCK SKEW Normal both channels
DRAM Command Rate : 2T
CAS# Latency : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : 3
Row Refresh Cycle Time : 55
Write Recovery Time : 6
Read to Precharge Time : 3
Read to Write Delay (S/D) : 8
Write to Read Delay (S) : 3
Write to Read Delay (D) : 5
Read to Read Delay (S) : 4
Read to Read Delay (D) : 6
Write to Write Delay (S) : 4
Write to Write Delay (D) : 6
Write to PRE Delay : 14
Read to PRE Delay : 5
PRE to PRE Delay : 1
ALL PRE to ACT Delay : 5
ALL PRE to REF Delay : 5
DRAM Static Read Control: Enabled
Ai Clock Twister : Stronger
Transaction Booster : Manual
Common Performance Level [7]
Pull-In of CHA PH1 Disabled
Pull-In of CHA PH2 Disabled
Pull-In of CHA PH3 Disabled
Pull-In of CHA PH4 Disabled
Pull-In of CHA PH5 Disabled
Pull-In of CHB PH1 Disabled
Pull-In of CHB PH2 Disabled
Pull-In of CHB PH3 Disabled
Pull-In of CHB PH4 Disabled
Pull-In of CHB PH5 Disabled
CPU Voltage : 1.35 (1.32 actual)
CPU PLL Voltage : 1.60
North Bridge Voltage : 1.51
DRAM Voltage : 2.12
FSB Termination Voltage : 1.22
South Bridge Voltage : 1.050
CPU GTL Reference : 0.67X
North Bridge GTL Reference : 0.67X
DDR2 Channel A REF Voltage : DDR2-REFF
DDR2 Channel B REF Voltage : DDR2-REFF
DDR2 Controller REF Voltage : DDR2-REFF
SB 1.5V Voltage : 1.5
My current bios setup
Extreme Tweaker
AI Overclock Tuner- Manual
Overclock from cpu level up- Auto
CPU Ratio- 8.5
FSB strap to Northbridge- Auto
FSB- 448
PCIE Frequency- 100
Dram Frequency- DDR2-1076MHz
Dram Command Rate- Auto
Dram CMD Skew A- Auto
Dram CMD Skew B- Auto
Dram CLK Skew A- Auto
Dram CLK Skew B- Auto
Dram Timing- Auto
CPU- 1.35v
CPU PLL- 1.5v
Northbridge- 1.49v
Dram- 2.00v
FSB- 1.36v
Southbridge- 1.050v
Southbridge 1.5- 1.5v
Dram Controller Voltage REF- Auto
Dram Channel A Voltage REF- Auto
Dram Channel B Voltage REF- Auto
CPU LED Selection- CPU Volts
NB LED- NB volta
Voltiminder LED- Enable
CPU Spread Spectrum- Disable
PCIE Spread Spectrum- Disable
Neither of your two setups managed to boot.
I need a higher NB volt to start with.
But for some reason OCCT and Prime (same code) drop 1 thread within 15 seconds of testing and the other one stops as a result of that (Code 1 / 4).
I'm running 3.6GHz atm which seems stable. And 4 seems stable too, but OCCT says differnet.
Win Vista x64 isn't a problem, when testing OCs?
Oh, I said it a few times before, but forgot to add it to the last post:
ASUS Maximus Formula Special Edition @ Rampage Formula 1410 (same results for both chipsets, got the feeling Rampage does a bit more, though)
Intel E8400 C0 (not sure about batch, sorry)
4x1 GB OCZ FlexXLC PC2-6400 CL3. POST + Boot @ 1066MHz
Windows Vista x64 SP1
Thanks for reading :)
I have got some screens and settings to post for you guys this evening. I got my 8600 4.5GHz stable today under water cooling. I will update my specs and post my settings and hopefully they will be of some use. :D
I couldnt get 3.8 stable so I went back to 3.6. I kept turning the vcore up but never got rid of the code errors on occt.
