Ok my HTT is running 295.6mhz and my ram is running at 255.0mhz
and 295 X10= 2950ghz
Wow, it's amazing what some cool temps can do for these CCB1E. Pretty cold in here right now, idle is about 20C (no coldbug btw at 334htt with ccb1e 0608mpmw). load is 28-30, running prime at 3006@1.375v.. it would always bsod here in warmer temps. Man, if I had a waterchiller to keep water at a constant 15C, I'd be set :D
Originally Posted by Malkec
well i get like 45 with 1.5 volts. my room is hot however. we dont use much A/C plus i have a very big window to the sunlight.
i have to have 2x120mm on my tunic to get temps like that @ 1.55v 2.8ghzQuote:
I'm not sure if my temps are considered hot. I think everyones temps get close to 50'C after hours of prime in the warmer parts of the world. 2.8 ghz @ a mere 1.4vcore dual core prime stable; I'm happy :woot:Quote:
I will try to push 2930 @ 1.4v tomorrow and get it dual prime stable. :)Quote:
Originally Posted by The Nemesis
Make sure you try lower htt multi's, once mine goes past ~340htt I need to lower to 2.5 or it freezes
dang, i wanna build a custom wc kit now. i want 3 GHz out of my 170. i can do 2.8 @ 1.5v all day long, but 2850 is so hard to achieve for some reason.
45c load at all times too.
Hey blazin how goes it?!Quote:
Originally Posted by blazin-asian
I know what you mean! i want to get water on my 165 to try to get past 2.8. 2.8@1.47 haven't got 2.85 stable yet. Know what it is though? core 0!! its stable at 2.8 and 1.47. Core 1 is stable at 2.8 and 1.42v!! Bugs me!! Idling at 42°C though
hey mastacator. i see you hang out here as well :D
core 1 is the weaker one for my opty. i can prime up to 2.9 or so on core 0, but 1 is a real slacker. no time to burn it in now because i have to pack up my desktop to move home at the end of the semester. just using the laptop for the next week or so.
yeah, my core 0 is the weaker one, but wow, 42*c idle!!??Quote:
Originally Posted by Mastactor
something needs to change, room temp or case ventilation or something
Yeah, I stumbled on to the site while researching this opty stepping.Quote:
I wish there was a way to help out one of the cores when one is weaker than the other.
So how,s East Lansing right now? I presume you going to MSU? I spent a few years in Michigan, 6 months in east lansing actually. Should be pretty nice this time of year.
I know, the idle started going up when the voltage was put to it, I think I am going to reseat my HS and probably check my PWMIC HS contact with the mosfets.Quote:
Originally Posted by nobody_here
I'm hoping to get my watercooling off the ground in a week or so.
well, after a few more days, i've had some trouble keeping it stable between 2900 and 2950. it definatly has to do with heat issues. i left the window open last night, it was 35F outside, and my load temps were like 43c @ 2950 @ 1.5v, primed all night, i shut the window in the morning and 20 minutes later it failed.
sold mine. ordered another one ill keep yall updated on what comes.
Friends for the 3 Gig Dualprimestable you need 1,35Vc at 2800mhz.
No chance to get 3 Gig with water if you need mor than 1,4Vc for 2800Mhz.
I get the 2.8 w/1.4 I can boot & run all kind of apps & games @ 3ghz but prime fails instantly on any voltage 1.4-1.55v. Any suggestions?Quote:
Originally Posted by Rufus7
Is you Ram 1:1 running?
Try it with an Divider. Some Chips don´t like high Ramclocks.
183 or 166.
You need this
http://img141.imageshack.us/img141/7...rime166.th.jpg
To get this
http://img150.imageshack.us/img150/7...e166tei.th.jpg
Rufus 1.456v in CPU-Z, what did you set in BIOS?
updated the db today if you want to check it out
haha, if by nice you mean all the short skirts and short shorts are coming out of their closets then YES. its VERY nice, lol.Quote:
but back on topic.....42c is VERY high for idle. is your pc by the heater or something? dang. i can pump like 1.55v and still keep under 35c idle. then again my pc sounds like a lawnmower with a jet engine :banana:
Ha Exactly!!Quote:
Ha!! No its not by a heater!! I dont' know what the deal is. I have an AC freezer 64 on it, and it has kept it pretty cool until lately. I'm getting water on it soon, hopefully, anyway. So I jumped on the bandwagon and bought from monarch last week. Hopeing to get a CCBBE 0610 stepping, should be here today.Quote:
well, i am currently testing my CCBWE 0609 FPAW, and it certainly isn't a good clocker. Currently trying 2.7 @ 1.4v. Will inform you asap.
I'm pretty sure this holds the record for "closest two cores as far as ocing is concerned"
http://img441.imageshack.us/img441/2...ores1oi.th.jpg
I think that record goes to Clint. He can't even get his cpu to make a core fail. It'll just freeze or reboot instead. Each of his cores are identical. It's really frightening.Quote:
Originally Posted by Repoman
Hey got a new 165 today.
Here it is:
New Opty
What do you think?
Should I put it in and give it a run?
