Any Non-TN 8-Bit Panels in this Bunch?
Great thread, I headed over to tftcentral and caught up on the rest. I'm trying to find a new widescreen LCD to replace this baby: Hyundai L90D+ which was all the craze about this time 2 years ago. I picked it up for a hefty (not so expensive for LCDs at that time) $337, and I want to spend that amount or less for my next LCD's final price.
So I looked at a bunch on newegg based on viewing angles (angle >= 170), response times (8ms or under), resolution (1680x1050 or greater) and size (bigger than 20"). I came up with a bunch, and I was curious if anyone had any experience with these before, or if anyone knew for sure if any of these were panels other than TN, and if they recommended any of these OR other ones for $350 or under? I took a good look at that NEC 20WMGX2 with the AS-IPS panel and sweet response time across the color spectrum (unlike the TN panels) and it amazed me. I want something like this, but I doubt a little over $300 is going to get me that far. I'm really looking for a good-looking make that I can trust similar to this, with the fastest speed possible, since this panel blows away all other TNs with its spectrum-consistent responsiveness (I am VERY sensitive to ghosting while playing FPS, specifically Counter-Strike: Source).
Anyways, here's the list I've already sorted through, if you can find one here that's not a TN panel that you recommend other than the first one (which I know is P-MVA and is my first choice if all the other ones turn out bad), please give me a heads up, or please make me another suggestion!
P-MVA: Acer AL2051W http://www.newegg.com/Product/Produc...82E16824009105
Unknowns I need advice on:
Hanns-G HG-216DP0 http://www.newegg.com/Product/Produc...82E16824254024
LG L204WT-SF http://www.newegg.com/Product/Produc...82E16824005085
Sceptre SW20C-Gamer http://www.newegg.com/Product/Produc...82E16824112003
X2Gen MW22R http://www.newegg.com/Product/Produc...82E16824222030
Hanns·G HW-223DPB http://www.newegg.com/Product/Produc...82E16824254020
AOC Monitor 212Va-1 http://www.newegg.com/Product/Produc...82E16824160006
AOC Monitor 22LVWk http://www.newegg.com/Product/Produc...82E16824160005
PLANAR PX2210MW http://www.newegg.com/Product/Produc...82E16824016083
Dream Monitors (out of my pricerange): NEC 20WMGX2 http://www.newegg.com/Product/Produc...82E16824002320
DoubleSight DS-240WB http://www.newegg.com/Product/Produc...82E16824185004
