If you think about it most of these MBs are used with air or water cooling. Then a few are used with SS or cascade. Then maybe fewer are used with dice. Then just a very few out of the total are used with LN2.
Based on my tests this CHV would be good for all the above cooling options but LN2 so if 5-10% of the total MB's had a problem running at extreme cold it should be rare to find one when testing under LN2. I don't know that every reviewer that received one of these to test would post out here in an open forum that they ran into a CB/CBB problem (I'm not talking about chew* as he probably would say something)? Maybe mine is one in a thousand for all I know?:shrug:
I still like the CHV a lot so I'll just bench it not so cold from now on.:)
