I have the same batch as you and mine runs really hot, I cant do anything with it on air...think I'm gonna sell it.
Even at stock? And you make sure heatsink is installed correctly? My temp at stock speed with underload all cores hover around 54-56. With 21x205 (4.305Ghz), all cores run around 79ish. This is on Scythe Mugen 2. I also have Extreme 120, which should run around the same temp.
found some more Bclks, this classified is awesome! not to mention batch# 3845B027
ifx-14 3fans, 1.381 Vcore, 239.4x21
http://valid.canardpc.com/show_oc.php?id=569733
I applied your suggestions and some of my own and the result was 5 more bclks. Can't thank you enough. :)
http://valid.canardpc.com/show_oc.php?id=569921
Here is a quick test of chip #1 on my bloodrage
Batch# 3849B028
Vcore 1.36
VTT 1.344
DIMM 1.616
I will test this chip on the classified as soon as I can....
Some Results from my 920 D0
http://www.abload.de/thumb/4510htonprimestablead53.jpg
1.5h Prime stable with HT on.
