First sorry for my bad english (french schools :p)
I have a rampage formula bios 0406 with a X3360 xeon CPU
Corsair pc8500 ram 2x1go dominator
The xeon cooling was a : Thermalright 120 Xtreme with a papst PWM
I was before on a crucial pc8500 8FE5 memory and it was very unstable and i changed for these corsairs
- ALL CPU tests Rockstable , OCCT CPU one hour
http://img376.imageshack.us/img376/3473/occt4bz3.jpg
But memtest on windows and OCCT ram very unstable , crash in less of 1 min...
http://img61.imageshack.us/img61/3907/occt2ht6.jpg
Also memtest with a boot cd was stable :
http://img364.imageshack.us/img364/8958/dsc00004so2.jpg
My temperatures was ok :
http://img67.imageshack.us/img67/332/tempkw7.jpg
I want to have my FSB450 in windows with strap 333 and 1071 mhz for the memory... But can't.
It was stable at FSB 445 , STRAP 400 , 1:1 with 1.51V vNB (very poor performances... 7239mb/s in everest read test)
FSB 445 , Strap 333 12:10 Unstable at 1.65vNB
FSB 450 , strap 400 , 1:1 : Stable only at 1.73 vNB !!!! and of course strap 333 always unstable
Noyau CPU 1.34 V
+3.3 V 3.28 V
+5 V 4.90 V
+12 V [ TRIAL VERSION ]
Mise en veille +5 V 4.97 V
FSB VTT 1.25 V
Noyau North Bridge 1.51 V
Noyau South Bridge 1.06 V
South Bridge PLL 1.52 V
DIMM 2.20 V
DIMM VTT 1.14 V
Memory :
CAS Latency (CL) 5T
RAS To CAS Delay (tRCD) 5T
RAS Precharge (tRP) 5T
RAS Active Time (tRAS) 15T
Row Refresh Cycle Time (tRFC) 60T
Command Rate (CR) 2T
RAS To RAS Delay (tRRD) 4T
Write Recovery Time (tWR) 14T
Read To Read Delay (tRTR) Same Rank: 4T, Different Rank: 6T
Read To Write Delay (tRTW) 8T
Write To Read Delay (tWTR) Same Rank: 11T, Different Rank: 5T
Write To Write Delay (tWTW) Same Rank: 4T, Different Rank: 6T
Read To Precharge Delay (tRTP) 5T
Write To Precharge Delay (tWTP) 14T
Precharge To Precharge Delay (tPTP) 1T
Refresh Period (tREF) 3120T
DRAM Read ODT 3T
DRAM Write ODT 6T
MCH Read ODT 8T
Performance Level 14
Read Delay Phase Adjust Neutral
DIMM1 Clock Fine Delay 8T
DIMM2 Clock Fine Delay 4T
DIMM3 Clock Fine Delay 8T
DIMM4 Clock Fine Delay 4T
What can i try? Change a paramater in my BIOS ? Or My ram? (corsairs bad with x48? Must i buy adata pc9600?) ? Or an issue with ma rampage and a should i do a RMA?
