Originally Posted by tatts
Sure of course in the Near.
http://img466.imageshack.us/img466/7...ewak2cq.th.jpg
Got a couple of 144's in on thursday. Got one in a system last night and went to town. CAB2E 0540 FPMW, Neo2 Plat w/ 1.c sideeffect.
Screen Shot:
http://i2.photobucket.com/albums/y17...y1441gigoc.jpg
cpuz verify:
http://valid.x86-secret.com/show_oc?id=49777
Still working on it, runs Prime95 stable for hours at 315, won't even hit windows at 320 so we might have a bit more headroom.
lol rufus, i meant the 148 is nowhere near the 146 even though there same steppings ;)
Sorry tatts. thx for the Screen from teh 148 CABYE 0540FPBW.
Good clockers. Nice clocks. Not so good as my CABNE but very good for a Productionweek.
no problem ;)
you saked for results of a 148 so you got a ss of 146 & 148 with same steppings to compare them :D
Both are very good, i will eventually buy an 148 CABYE 0540 FPBW pretested at 3Gig and 1,48Vc on Aircooling next Week.My HS sucks next Week i will take him off. hoping for better Temps.
Current test run - 310x10
http://img256.imageshack.us/img256/4...occt1ad.th.jpg
Not so good for an Vapochill cooled Opteron.
Here´s a little Steppinglist from Germany.With all Opterons available for S939. ;)
http://www.forumdeluxx.de/forum/showthread.php?t=171147
Glad to see they have that running again. That's a very good thread.Quote:
Originally Posted by Rufus7
Didn't anybody notice Moonman's OC? That pretty much pwned.
It's good but not great. The reason is he is on phase. That means nonpwned.Quote:
Originally Posted by manomanx2
OSA148DAA5BN
CAB2E 0540 FPMW
Batch 0166
Still working on getting this one tuned in but so far completed OCCT @ 2800 (10 x 280 1:1) with 1.32v.
Question I have is that the CPU seems to be running hot at 47C max during test. According to Central Brain Identifier Max T Case is 63C with a Thermal Offset of 12C. This compares to my old 3700 Sandy at 59C T Case and a 3C Offset.
Would this explain the high temps and if so how should I account for the 12C offset?
Empty
Very good cooling. :)Quote:
Originally Posted by empty1969
CABGE so it's great.Quote:
Originally Posted by dogsx2
That temps are very close to early CABNEs...Interesting :)Quote:
Are new chips really falling over at this low MHz 1:1? I know there's something in my system that's not letting me run 166 divider on my CAB2E (that would mean 2.5-3-3 ~250 on TCCD, which is fine) but is fine with 133 (2-2-2 ~200) - could it really be the chip?Quote:
Originally Posted by dnottis
Reached 3000, nothing exceptionnal for this stepping, but it's the first time for me in the AMD world.
I ran Prime 10 hours last night at 296*10 (same vcore)
RAM timings are pretty relaxed (running 166 divider); I'll try to run 200 or 180 when the CPU has reached its limits.
Those opterons have an unusual behavior: Usually when I need to bump the Vcore I know the chip limit is 200-300 mhz higher. Here I had to raise from default Vcore at 2700 (And thought it would be difficult to reach 3000 with "raisonable" voltages), but it's still going! Very impressive chips indeed.
how's this for fast :)
http://www.fileshosts.com/DFI/NF4_SL...rpi-32m_tn.jpg
sub 26s 1M
http://www.fileshosts.com/DFI/NF4_SL..._25969s_tn.jpg
Opteron 144 cabe2e 0540 fpmw
Cooling: Thermaltake Silent Boost (21dBA 27.5cfm - i.e rubbish fan!)
Temperatures are a bit warm due to low cfm fan. Unable to max out the RAM ATM due to no active cooling in place
http://premium1.uploadit.org/glorfy//tn_2906ps.gif
http://premium1.uploadit.org/glorfy//tn_sp32at2906.png
Yep, all these CAB2E 144s seem to be doing about the same on air/water - 2.9, give or take.
It'll do 3GHz, but it takes 1.64v.Quote:
Originally Posted by Kameleon
http://img355.imageshack.us/img355/9...mhz260785g.jpg
Opteron 146 cabye 0540 fpbw
my wonderful 146 CABYE 0540FPBW now on watercooling & advancing very nicely, 35C idle 41C full load :toast:
still priming before going for the 3.3ghz :banana:
http://valid.x86-secret.com/show_oc?id=50146
http://img246.imageshack.us/img246/1...x3206oh.th.jpg
Help! Help! Help! could anyone show me the results and screenshots of opteron single core running at about or something 3.8GHz if i'm not wrong, i think the fastest superPI run... i forget to bookmark the link...
You got a gold ex there.Quote:
OPP had one opty 154 at 3781Mhz :Quote:
Originally Posted by Pirated
http://www.xtremesystems.org/forums/...53#post1133453
overcrash86: thanks for the info and help...
Here is mine CABYE 0540 FPBW under water...
http://img256.imageshack.us/img256/7407/clip1be.jpg
Still testing it...but all 4 we have ordered are really hot...about 5°C more than an 148 at same speed and same voltage :rolleyes:
Regards,
Primoz
Very Nice Tatts, but Only SuperPi. Prime is the only stability test that counts.Quote:
The Rest is only for Benching good.
http://img176.imageshack.us/img176/3...bujo0tt.th.jpg
silencer 64 ultra :D
This opteron is normal, for christmas a 146
Which are the best Opteron 148 steppings until now?
Updated.
http://files.upl.silentwhisper.net/u...mhzsuperpi.JPG
http://files.upl.silentwhisper.net/u...22verified.JPG
Air cooled + forgot to set fan = on when temps where lower than 35c(idle temps).
E6 :DQuote:
Originally Posted by Monge
Mhm nice one Lastviking! Which aircooler?
i'm curious if low batch number means good overclocking. Is there some kind of online database with batch numbers and OC's?
Great result Lastviking! Go Sweden :D
Hope I'll recive a CABYE 0540 next week :)
where on earth you guys getting 0540 cabye's ?
Originally Posted by SPivX
lower batch number does not guaranteed better overclock, few weeks ago I bought three 148 cabne 0528 but the one with highest batch clocked higher, required less vcore, and with MaxTcase of 67'C instead of 63'C like the rest of the lower batch.
I have never seen Opteron 148 E6 - is this new?Quote:
Originally Posted by Martin Cracauer
I meant: Which are the best Opty 148 steppings (codes) to look for?
do you believe in MaxTcase? There are Opteron's with MaxTcase 55 that do 3000+ on air / water... My two 146 CABYE 0540 FPMW with batch 0001 and 0230 will come in monday or tuesday. I'll let you know!Quote:
Originally Posted by ben805
TT Big typhoonQuote:
Originally Posted by ManagHead
thanks, i run it for 5 hours earlier and no errors so gonna try pushing it to its limits before finding a 24/7 stable clock :DQuote:
i wouldnt bother, my 146 & 148 are exact steppings & week but the 146 is on 3.2ghz and the 148 scrapped 3ghzQuote:
nope, the batch with 0500 seems to be the best from what ive seenQuote:
yes, the 146 0540 will hit 3ghz no problem were the 144 0536 will be around 2.8ghz
http://img407.imageshack.us/img407/3...hz255633fd.jpg
:banana: :banana:
Gj :toast:Quote:
Originally Posted by GUFY
Opty 146 CABYE 0540FPAW, batch 0050. From Newegg. Using Thermaltake Big Typhoon for cooling.
http://www.3dxtreme.net/other/CPUS/O...-12hrprime.jpg
Originally Posted by Lastviking
Is that PRIME stable though?
Opteron 146, 0530 CABNE iirc, batchno. 030
IHS still on...
http://img487.imageshack.us/img487/4...5spi32m0qt.jpg
HL² gaming stable. Using 7/10 divider atm. OS untweaked XP for gaming etc.
This is really odd....I can run SP2004 for hours at 2900mhz but I cant run 1m at 2840mhz....it will error out...anyone got any ideas?
...ram maybe?
its my tccd on 5/6 207mhz 2.5-4-4-8
maybe not ram...lol....hows teh voltage in your PSU...rails nice and stable?
New 150 CABNE... Memory was at 1/2 in this shot. This also was on stock HSF, waiting to hear more about SLi Expert board eating CPU's before I install in the Vaporchill.....
http://www.gadtek.com/150-2-1.jpg
CABYE 0540FPBW is the best for 146 now and for the 148 also.
...I think you could be wright but...are really really hot!...I an my @3ghz 1,424V SP2004 for 8 hours and get temperatures around 47-48°C under water!...I think will remove the HS this week... :stick:Quote:
Regards,
Primoz
Nice to see you back in action SAE :toast:Quote:
Originally Posted by SAE
heheh new personal record :) with icewater
http://img352.imageshack.us/img352/9529/jee22uu.png
:woot:
I picked up a couple in Hong Kong ...Quote:
Originally Posted by TEDY
Got mine hereQuote:
I don't know your block, but I get 29 idle - 38 Load with a Nexxos XP, at 3050 Mhz.Quote:
Originally Posted by Primoz78
still cooled by puny 1/4" tubed Corsair Hydrocool 200 in 30+ C room temps
Awesome broke 23m 10s barrier
Super Pi 32M
@3102mhz = 23m 23.735s
@3120mhz = 23m 14.547s
@3130mhz = 23m 10.297s
@3133mhz = 23m 08.500s
@3141mhz = 23m 05.891s
@3150mhz = 23m 03.531s
but higher isn't better either. i'm the owner of a CABNE 0530APMW #0001. it does 2.9ghz with 1.425v, not the best, but also definitly not bad ;)Quote:
it really comes down to luck more than anythin else
We have ordered 4 of this CPU`s with same stepping...and all 4 have the same issue with temps...so the blocks are OK... :rolleyes:Quote:
Originally Posted by skogkatt
Regards,
Primoz
Primoz78: What's the room ambient temp?
146 CABYE 0540FPBW
- 2900MHz 1.408Vcore StressPrime +28h stable
Now 3006MHz 1.408V, 2x256mb Corsair BH5 273FSB 2-2-5-2-7-13 1T 3.6V, StressPrime has run now 45min., let's hunt for +24h :D
Cooling: TT BigTyphoon, ambient around 23ºC -> CPU 40-43ºC under stress
About 18-20°C...I`m wondering what will be the temperature in summer months... :confused:Quote:
Regards,
Primoz
Not sure I'm getting your answer...I was wondering if your water block was good enough (or your WC system). Of course if your room temperature is around 30C that could explain your results ;)Quote:
Ok.Quote:
Did you try to measure max. T-case and thermal offset with CBI or another program - I don't remember the name?
Maybe it has to do with the core/IHS.
Edit: Here you go:
http://www.thecoolest.zerobrains.com...topic.php?t=83
http://users.skynet.be/pt1t/146/prime_3200mhz.PNG
opteron 146 CABYE 0540 FBPW #224
Watercooling
ambiant temp ~ 17°
Full ~ 47°
Thats normal for an 146Opti 0540FPBW.
Heres a link for similar clocks but Prime 95
http://monsterprozi.mo.funpic.de/opt146html.htm
yep this 146 cabyes 0540 FPBW re very good i ordered last one today for a friend mine here in portugal for 180euros , the other guys who bought the others 146 cabye 0540 fpbw in same store all of them hit 3000mhz@1.45v aircooling . :DQuote:
Originally Posted by Dani
Maxtcase is 59°C...thermal offest...don`t really know what is ths... :confused:Quote:
Regards,
Primoz
Orderd a 146 CAYE yesterday, from www.komplett.se it seems like all of komplett´s 146es are CABYE 0540 :D
I think you need CBID to read thermal offset:Quote:
http://cbid.amdclub.ru/html/download.html
Read about max. T-case and thermal offset here in this thread:
http://www.i4memory.com/showthread.p...9&page=1&pp=30
There's also a thread here on XS.
Monge :toast:
Yep, it's the same here in Norway too. Think I'll mine on Wednesday, thought Komplett sent it on Saturday, but it was sent today :(Quote:
Originally Posted by Wiker
I got a 146 CABYE 0540 FPMW from CPUCity today, gonna see how it clocks soon :D
Thx...I already got the CBID ;) ...maxtcase is 59°C as I said before thermal offset is 3°C...Quote:
Regards,
Primoz
Hmm i got 2x 146 same stepping fpbw one has MaxTcase 63 and the another MaxTcase 63
1. MaxTcase 61c = much better of them about 80mhz+ more 24/7 speed 3040mhz+
2. MaxTcase 63c = very hard to go higher than 2950mhz super pi m1.
Lower MaxTcase gooder?
i dunno, but i think that maxT thing is all BS anyways, my opty read 57°, but it clocks up to 2.9ghz on air and stable.
After 2x8 hours of SP2004 I can get my 146 stable at 3ghz at 1,408V...but not stable at 3,1ghz with 1,5V...
Regards,
Primoz
It might be that the temps go too high @ 1.5V and SP fails. @ 1.4V temps still are ok and that is why it passes....Quote:
+8h30min now @ above settings :cool:Quote:
Nice rams...
I probably missed it but how do you see the MaxTcase?Quote:
Garrett :
with a little proggy, called AMD64 MaxTcase.
You can DL it here :
http://www.thecoolest.zerobrains.com...fcc78b2367901c
Thanks Jupiler :thumbsup:
(moet ik toch beter zoeken volgende keer lol)
Hey man, np. :)
My 2 146's shipped today from Alternate. Hope to get them pretty soon, and that they're from a good batch.
Thx again for the help. :toast:
XP90c sucks lmao...
144 CAB2E 0540FPMW
http://img.photobucket.com/albums/v518/ZX7891/2900.jpg
I got an Opteron 146 PIB from Monarch earlier:
CABYE 0540FPMW #87 Max t-case 63c
I've only had it on water cooling with a Maze3 block so far.(IHS still on)
Stock voltage (1.40v in bios) got it upto 2800MHz stable.
1.425 2850MHz stable
1.475 2900MHz stable
1.525 2950MHz looks stable but i'm still testing.
I'm pleased with it so far, snagged it when it was $159USD ;)
My goal as many others is 3Ghz which i think will happen with more testing and tuning.
Still testing this, Prime95 stability is important. Using Big Typhoon.
http://www.3dxtreme.net/other/CPUS/O...W/IMG_2303.jpg
Heres mine. Went to 2.83 @ stock voltage. Heres my max on air, dont want to go higher till I get better cooling.
I can't read all this stuff....Any ideas about "good" steppings in 170 or 165???
More in the Unofficial "dual core" opteron thread...Quote:
Originally Posted by Hydrus
My 146 Opty is sitting at my houes waiting for me to come home and install it. I will get back Wednesday and hopefully have some numbers up by thursday night. I also got my RETAIL 146 for 159. Man, what a steal. If this thing even hits 2.7ghz, my 3500+ venice is out the door fo shizzle. From the sounds of things I am looking closer to 2800-2900 without hitting voltage even. MY lonely Venice stopped @ 2550 with stock vcore.
If you get a CABYE or CABNE I can almost gaurantee 2.7-2.8 with stock voltage. This is by far the most stable ive had. The better silicon quality really makes these opterons so worthy of overclocking.Quote:
Originally Posted by Rickster_64
Thanks for posting Prime95 results dnottis. Looking good :)Quote:
all right.
CABNE 0530APMW 2.9 ghz stable with only 1.45 volts
CABYE 0540FPMW 2.9 ghz testing with only 1.45 volts
i can get it OCCT stable at 3 ghz with 1.47 volts but can't get it to prime for longer than 10 minutes.
am I board limited or am just having awesome bad luck (2.9 is awesome but can't get to 3.0 which is bad)?
After a 2 x 8hours of SP2004 @ 3ghz 1.424V I`m now able to run it at same speed with 1.408V :toast: But can`t get it stable at 3.1ghz even at 1.5V...and can`t get to windows at 3.2ghz with 1.55V... :slapass:
Regards,
Primoz
Well Kohan got his 146 today. went over to his house and clocked it up on stock cooling.
It did 2.9ghz with 1.45volts in bios which relates to 1.4 in windows. At 1.375 (windows) it is stable up to 2.85ghz
the stepping is 0540 CABYE.. which as most of you have said are the golden chips and this one didnt disapoint.
btw this was all done on stock cooling and thermal pad. I imagine with some better cooling it will do 3ghz stable with 1.45volts.. MAYBE will need 1.5-1.55 for 3ghz.. Either way its one hell of a chip..
for reference, chip was had at monarch on thursday via retail box.
I will be getting my 146 from monarch tommorow, baring FedEx continuing to be a-holes.
Originally Posted by MaxxxRacer
im getting 146 0540 from tankguys tomoro ... fedex as well.. :) ... now i dunno whether to keep my 165 @2.7Ghz... or use the 146 @ 3Ghz... :rolleyes:
for most things the 165 would be better.. for 3dmark and super pi the 146 would be better. so i guess it maters waht ur doing.
soon enough everythign will be multi-threaded atleast to some extent and it wont be a contest.. but for now its highly application dependant.
