Jeebus. That has got to be the most performance you can squeeze out of a C2D at 4.0Ghz for 24/7 stable :D Nice!
Thanks for posting those settings Radaja. I think once I move home and get my dedicated room sorted, I'll be tempted to try an E8500 on my USB3P. I got over 600 fsb with it on an MIIF (I think I hit something like 617) so it's not out of sight - just a shame mine needs lots of volts for anything above 4.1-4.2. Stability at 572 seems like a nice indicator that the same is possible on this board, hopefully the DDR3 will be up to the same. Skews definitely played a part on the MIIF so I'm sure you'll go further when you aim higher - well done. I can only hope for results like that!
Looking at buying a Q9650 with a VID of 1.200....will I need a water setup for 4 GHz (8x500fsb)?
ok, well Sergio helped me on some settings with my USB3P and this high VID Q6600..... but i thought i would post my info here and see if there is anyone with some good info to get this stable.
then i have it currently set to this...Quote:
Q6600 VID 1.325
Core Temps 19 21 19 16
445 x 9.0
CPU PLL 1.570 - 1.570
Term 1.280 - 1.520
CPU Ref 0.745 - 0.785
Vcore 1.7 - 1.7 ()
Dram Volt 1.8 - 1.9
Dram Term 0.750 - 0.750
Ch-A Data vRef 0.75 - 0.75
Ch-B Data vRef 0.75 - 0.75
Ch-A Address vRef 0.75 - 0.75
Ch-B Address vRef 0.75 - 0.75
MCH Core 1.46 - 1.40
MCH/DRAM Ref 0.75 - 0.75
MCH Ref 0.76 - 0.80
ICH I/O 1.570 - 1.570
ICH Core 1.20 - 1.20
Skews are
100ps
150ps
Memory DDR3 4GB
534.1
5:6
8-8-8-20 60 2T
i can boot into windows and open memset, cpuz, et6 and everything is fine. Prime fails and freezes solid in .5 seconds.
If i try SuperPi 1M it makes it to the 4th loop and freezes then reboots.
With these settings i am not seeing BSOD just freezes and reboots.
The goal with this........... 42xx.x
Oh and a strange thing.... with these exact settings XP won't even load, if i drop FSB to 442 i can get into XP and run Wprime and SuperPi 1M
In Vista it loads and can move around inside windows i just cant stress it because it freezes instantly.
Advanced Clock Controls are:Quote:
these are current settings at 444*9
PLL 1.57
Term 1.52
Ref 0.670
Vcore 1.760
Dram Volt 1.90
MCH core 1.52
MCH Ref 0.80
I/O 1.57
ICH Core 1.20
CPU 1000mv
PCI 1000mv
CPU 0ps
MCH 50ps
Enhance Standard
XMP Disabled
Latch 333
Multi 2.40B
i am running A-Data DDR3 2000 XPG G Series
CL9 9-9-24
any help would be grateful
q9550 @ 4.4 GH v1.328
with UD3P rev 1.1
Qspi 16 MB, passed !
http://img31.imageshack.us/img31/7851/44ghqspi16mb.jpg
one of templates
http://img684.imageshack.us/img684/3998/dsc00430co.jpg
http://img69.imageshack.us/img69/9228/44vantager.jpg
Well today my new toyz arrived so i will be off of P45 i will remember this thread forever :D
thank you very much my friends OC nub and l0ud_sil3nc3 for the kindness and patience on this days, i really appreciatte that very much guys :up:
sompe pics of my first X58 mobo and my first I7 920
http://img259.imageshack.us/img259/884/p10602271.jpg
http://img819.imageshack.us/img819/5668/p10602391.jpg
cheers all :toast:
Sergio
nice
but for daily use CPU Termination is not too high ?
Advanced Clock Controls which setting ?
thanks
here put 4.3ghz (506x8.5), ran in Standard mode LinX
but not anymore, I do not know whether it should be by high temperature :(
vcore 1.36250v
vfsb 1.36v
pll 1.57v
ref 0.886
VNB 1.46v
ref 0.901
ich 1.50v
ich c. 1.20v
Hey congrats Sergio going to be nice . . . love to see that I7 920 makes my mouth water . . . you know i couldnt be left behind so my X58 and 920 coming alsoQuote:
didn't want to leave the EP45-UD3P club here , after I sold mt Q9650 . . so i put a E8400 in her and she fun all over again . . but i did run in some bumps I thought with the settings of the Q9650 the E8400 Would PURRRRRR wrong crash crash crash on prime . . Radaja came thru with a template , now my lan system is kicking some prime ass again. Thanks Radaja :up:
http://i84.photobucket.com/albums/k7...8400at4050.png
For anyone that may be interested I updated my bios from the F9 to the F10 on a EP45-UD3P Rev.1.0 and started having that boot loop issue tried clearing the bios and loading optimized default setting still wouldn't post just keep looping so i took a shot and loaded the F11C Beta Bios That instantly solved the boot problem even seems to boot much quicker and load windows faster
Here's the link to the F11C bios I used
http://www.station-drivers.com/page/...-ep45-ud3p.htm
Congrats Sergio, hope you will enjoy.
Glad you finally got it buddy I am sure you will have a blast playing with it.
Bah Sergio I7 :p I7 is for pussies, too easy :)
here 4.2 GH stability test
IBT v2.5, HIGH, 15xLopps - PASSED
http://img707.imageshack.us/img707/5...gh15xloops.jpg
Q spi 32 MB - PASSED
http://img838.imageshack.us/img838/6571/32mb42.jpg
niggro please , sergio knows what a i7 is and has pushed the 775 as far as it can go , more than you Leeghoofd Im sureQuote:
Dont worry Sergio, you would only be a ":banana::banana::banana::banana::banana:" if you ran your i7 on LN2. I know you will find max oc using a 24/7 cooling solution.
You have done a lot for this thread along with quite a few others, and have always been there to help people when they needed it. This has been a great thread with a lot of good people posting that have been more than willing to help, something I havent seen in many other threads.
