i haven't problems with the temp, because there is an 120mm fan in the front.
it cooles HDD's an the DDC.
Its just warm, but not to hot for overheat :D
greetz
greetz
just a suggestion cause ive seen those ddc's fry without airflow under the pump for the motor.
http://img222.imageshack.us/img222/3...0038ki4.th.jpg
Thought I would share my res.
What the hell is in that thing Gore?
That is my res. I didn't properly clean out my PA120.3.
Here is my EK 8800 block.
http://img222.imageshack.us/img222/7...0040qp4.th.jpg
Lol, I washed the FC8800 block 2 days ago and it's worse than this. Like you, I didn't clean the PA120.3 sufficienly.
To remove this dirt, you need to use vinegar with salt first to remove the tarnish and show the copper. After this, rinse with water and arm & hammer to neutralize the vinegar then rinse thoroughly.
Here is my pump. First time I have ever opened it :P
http://img222.imageshack.us/img222/9...0041or7.th.jpg
oh wtf
ouch town, population you bro. (yes i know corny dodgeball quote, but i feel it was necessary.)
Im guessing you only used distilled water then, no anti-bacteria or a corrosion inhibitor or anything?
So how do you rinse Thermochill rads right? I rinsed mine with boiling distilled water and no flux or anything came out, it was clear. What am I doing wrong?
Shake it baby!
Less chat and more pics of completed watercooled systems.
Now thats just a work of art!
Nice one, again Dualbrain
+1
HotGore, nice and clean there mate :D
Sometimes you can start wondering why thermochill won't clean the rads in factory. I mean, of course there are beginners out there that aren't aware of the dirtyness of these rads, which basically makes their loops doomed from the beginning. Also the rads are quite expensive, so I think you could expect a little bit better painjob and a rinse.
Just a couple of pics for the fun :)
Please take a look at my high quality PC pics I made a while ago! Here is the wallpaperpack.rar DL link: http://rapidshare.com/files/92671777...rpack.rar.html
Attachment 72492
Attachment 72493
Attachment 72494
Attachment 72495
