Do you guys have CPU VOLTAGE and EIST using 2604 Bios ?
because EIST is gone and it says to disable it for changing voltage, well of course but its not there and its Enabled. What's wrong with it grr, i cant do any overclock without changing the cpu voltage.
***** NEVER MIND : i found the fix, Disabling the CPU RATIO makes it EIST to appear and then i can change the CPU VOLTAGE.
