Yeah tried 1.1v
Shouldnt need more than that I would assume? Only running 2 X 4GB @ DDR-1600 7-8-7-24-1t
Thanks for the test feedback, sin. Hopefully Ud5 is similar....
Remember that DES2 overvolt problem i was talking about a few pages back. Well i got a reply from gigabyte who just said AIDA 64 doesn't report the right voltage (it didn't in previous versions)
anyhow here is a link to a post i made earlier today with a Fraps video of DES 2 increasing my voltage to 1.59.
http://www.xtremesystems.org/forums/...d.php?t=266044
I thought you guys might be interesed. I've also sent the video off to Gigabyte so i'll let you know what they say.
how many are you are going to RMA your boards?
I get mine tommorrow give me a chance to try and break it,if i cant in a two or three weeks time its staying.
Does anyone see something?
First benchdisk was done 1 week ago & 2nd just done.
I use all 4 sata ports.
Look at the difference, it's huge.
Started. Overtime ehh? 1 Week & it's aready started.
Re: Intel Corporation has discovered a design issue in a recently released support chip, the Intel® 6 Series, code-named Cougar Point, and has implemented a silicon fix. In some cases, the Serial-ATA (SATA) ports within the chipsets may degrade over time, potentially impacting the performance or functionality of SATA-linked devices such as hard disk drives and DVD-drives
why not ghost that drive and then reinstall it from scratch again and retest and see what happens,
Uhh,my DVD drive disappear or letter gone a few times.:yepp:
just try it man
:up::up:
My UD7 and I2600k are arriving tomorrow from the egg to a friends house on the US, im on a loop deciding what to do as ones it gets to South America i will have no chances to RMA...shoul i reject the order ?
thanks for the help guys
Sergio
I would send the board back if you cant RMA from your country.
correct my if im wrong guys
Chipset:
NOT AFFECTED
1) 2 x SATA 6Gb/s connectors (SATA3_0, SATA3_1) supporting up to 2 SATA 6Gb/s devices
(AFFECTED)
2) 4 x SATA 3Gb/s connectors (SATA2_2~SATA2_5) supporting up to 4 SATA 3Gb/s devices
3.Support for SATA RAID 0, RAID 1, RAID 5, and RAID 10
NOT AFFECTED
3) 2 x Marvell 88SE9128 chips:
3.1) 2 x SATA 6Gb/s connectors (GSATA3_6, GSATA3_7) supporting up to 2 SATA 6Gb/s devices
3.2) 2.Support for SATA RAID 0 and RAID 1
2 x eSATA 6Gb/s connectors (eSATA/USB Combo) on the back panel supporting up to 2 SATA 6Gb/s devices
so im my case that i use SSD as boot and 3 x HDD RAID0 can i do this with the avaiable options ? guess 4 sata ports not affected but dunno if i can combine Marvell with the others...
as per my PM
These are running off a second Marvel SATA6 controller so they have nothing to do with this issue Intel announced todayQuote:
yup just as I thought
