207/209 seems way too low... have you already tried even the older bioses?
Those were the settings we used yesterday evening to reach 220 bclk stable @1M.
Where there's nothing written, that's because we leaved it on auto. ;)
Code:
GIGABYTE GA-X58A-UD7
MB Intelligent Tweaker(M.I.T.)
Advanced CPU Features {Press Enter]
CPU Clock Ratio............................: 15x
CPU Frequency .....(Ghz)...................: 3300
Intel(R) Turbo Boost Tech..................: enabled
CPU Cores Enabled..........................: all
CPU Multi Threading........................: disabled
CPU Enhanced Halt (C1E)....................: disabled
C3/C6/C7 State Support.....................: disabled
CPU Thermal Monitor........................: disabled
CPU EIST Function..........................: disabled
Bi-Directional PROCHOT.....................: disabled
Virtualization Technology..................: disabled
Uncore & QPI Features [Press Enter]
QPI Clock Ratio*...........................: 36x
QPI Link Speed* ......................(Ghz): 7,92
Uncore Clock Ratio.........................: 17x
Uncore Frequency......................(Mhz): 3740
Isochronous Support........................: disabled
Advanced Clock Control [Press Enter]
>>>>>Standard Clock Control
Base Clock (BCLK) Control*.................:
BCLK Frequency (Mhz)*......................: 220
PCI Exxpress Frequency (Mhz)...............: 112
CPU Clock Drive (mV).......................: 800
PCI Express Clock Drive (mV)..............: 900
CPU Clock Skew (ps)........................: 0
IOH Clock Skew (ps)........................: 0
Advanced Dram Features [Press Enter}
Performance Enhance........................: standard
Extreme Memory Profile (X.M.P.)............:
System Memory Multiplier (SPD).............: 6x
Memory Frequency (Mhz).....................: 1320
DRAM Timing Selectable (sPD) ..............:
Channel Interleaving............................:
Rank Interleaving................................:
Channel A Timing Settings Sub Menu [Press Enter]
>>>>>Channel A Standard Timing Control
Cas Latency Time.............................: 8
tRCD.........................................: 8
tRP..........................................: 8
tRAS.........................................: 21
>>>>>Channel A Advanced Timing Control
tRC..........................................:
tRRD ........................................:
tWTR ........................................:
tWR..........................................:
tWTP.........................................:
tWL..........................................:
tRFC.........................................:
tRTP.........................................:
tFAW.........................................:
Command Rate (CMD) .....................:
>>>>>Channel A Misc Timing Control
B2B CAS Delay................................:
Round Trip Latency...........................:
Channel A Turnaround Setting [Press Enter]
>>>>> Channel A Reads Followed By Reads
Different DIMMs..............................:
Different Ranks..............................:
On The Same Rank.............................:
>>>>> Channel A Writes Followed By Writes
Channel B Timing Settings Sub Menu [Press Enter]
>>>>>Channel B Standard Timing Control
>>>>>Channel B Advanced Timing Control
Command Rate (CMD) ..........................:
>>>>>Channel B Misc Timing Control
Channel B Turnaround Setting [Press Enter]
>>>>> Channel B Reads Followed By Reads
>>>>> Channel B Writes Followed By Writes
Channel C Timing Settings Sub Menu [Press Enter]
>>>>>Channel C Standard Timing Control
>>>>>Channel C Advanced Timing Control
>>>>>Channel C Misc Timing Control
>>>>> Channel C Reads Followed By Reads
>>>>> Channel C Writes Followed By Writes
Advanced Voltage Control [Press Enter]
>>>>CPU Voltages
LoadLine Calibration.........................: lv1
CPU Vcore....................................: 1.325
QPI/VTT Voltage..............................: 1.61
CPU PLL......................................: 1.8
>>>>>MCH/ICH Voltrage
PCIE.........................................: 1.64
QPI PLL......................................: 1.32
IOH Core.....................................: 1.34
ICH I/O......................................: 1.5
ICH Core.....................................: 1.1
>>>>>Dram
DRAM Voltage.................................: 1.68
DRAM Termination.............................:
Ch-A Data Vref...............................:
Ch-B Data Vref...............................:
Ch-C Data VRef...............................:
Ch-A Address Vref............................:
Ch-B Address Vref............................:
Ch-C Address VRef............................:
