raise your qpi/vtt a couple bumps as well as pll
Thanks.
Metroid and DJ88 what are your batchnumbers plz?
nilos go back like 4 pages they already posted them
Nice 24-7 for me looks like 3.7- 3.8 is perfect for air 24-7 without stock heat sink. I need better cooling load temps are to high for 24-7 @4g , my load temps were way to high so i did a nice prime at moderate 3.3 27 hrs I dont like seeing it that high of a load temp. Love these new chips:yepp: I especially love the 4 cores 8 threads. Im waiting for the next round of heat sinks :toast:
http://i137.photobucket.com/albums/q...rboenabled.jpg
http://i137.photobucket.com/albums/q...er1st/full.jpg
http://i137.photobucket.com/albums/q...t/Snap1-16.jpg
http://i137.photobucket.com/albums/q...pusinjulia.jpg
http://i137.photobucket.com/albums/q...photoworks.jpg
http://i137.photobucket.com/albums/q...1st/sisoft.jpg
http://i137.photobucket.com/albums/q...t/prime3-1.jpg
On the stock cooler of the 920, I was able to boot up windows and get a cpu-z validated shot of 4GHz. All I did was set the bclock to 211 * 19, the vcore to 1.325v, vpll to 1.9v, and the memory, qpi and uncore multipliers to lowest. Again this is all on stock cooling.
Is that at all impressive or noteworthy compared to others? It was not prime stable, the system froze shortly after starting prime. However I can get 3.8GHz prime stable, haven't tried 3.9ghz. For the third and final time, this is all stock cooling and 2min in the BIOS. Temps have hit 100C with this configuration.
Once DD gets me my new top for my MPC-X38 and D-Tek gets the mounting kit for the Fuzion V2, I will be putting the CPU and chipset under water. About what can I expect with water cooling based on what I've done on stock?
EDIT:
Forgot to mention, turbo mode is disabled for all of this.
Just Got my i7 920 running, here are the results
GA-x58 ud5
920 C0 rev, F4i bios
hyperthreading off
Patriot 999 DDR3, 3x2GB
Tuniq tower 120
Attachment 90352
I sort of cheated in that I benched with HT off, but that is no good for normal everyday use. Reason is Vista sleep mode doesn't work if HT is disabled. Struggling with this reminded me of the bad old days of XP with it's 90 second boot times. With vista, 10 sec is the norm, so HT on is a must.
No problem.:)
Prime 95 - 3705Mhz - V.core 1.088v:;)
http://img514.imageshack.us/img514/3...8263qb2.th.jpg
By:)
No luck for me using R2E with a Core i7 940. I already tried two CPUs and the highest rock solid stable I can get is 3.8GHz (19x200MHz) with 1.28V in BIOS, QPI/DRAM voltage is at 1.43750 in BIOS. Ram is Corsair Dominator 1600 @ 1600MHz with 7-8-7-22 timings at 1.65V in BIOS. Air cooling with CoolerMaster V8.
I do not know how everyone is managing 4GHz OCs even with 920 when I cannot even get any of the 940s to 4GHz. Maybe it's my cooling? Temps are maxing out at 77C (ambient is about 22C).
This is starting to suck badly...why pay for a 940 when it works no better than any 920 out there...
Any others users with R2E and a 920/940 on air to give some tips on breaking that damned 4GHz mark? These chips are supposed to be higher binned than 920s but maybe w/out WC or something better they cannot fully stretch their legs?
Any tips appreciated!
RealTemp beta link:
http://www.fileden.com/files/2008/3/...alTempBeta.zip
Save that link. It hasn't changed for months.
It's winter time here so there has been lots of time for updates recently. :)
Why would loosening up your ram timings help? I always thought that tighter ram timings were a good thing....
I've been having the same problem. I've managed to get (197 x 21) a lot more stable than the other ones. It seems that for me that 200+ BCLK isn't working, so I'm ok with 4.137 GHz at 1.344(1.3875 in bios)
I'll experiment a bit more and see if I can get anything stable at 200+ BCLK
Thanks,
Well to tell you the truth. I found out if you feed it with 13 to 16x then my system will boot with low voltage and it is more stable. I know it is strange. The memory has to be 6x and Uncore 13 to 16x. If the memory is x8 then the Uncore should be 17 to 20x.
I hope this info will help you guys out on the quest of getting a very good lower voltage with higher clocks.
No pics, I'm using the gravity method right now. That is, I set my case down flat on it's side and the HS is just sitting on the top of the 920 with some light bracing. Tomorrow, I'm going to make a proper hold down by screwing down a piece of sheet metal to each end of stock 'H' hold down to effectively enlage it so that it extends beyond the mobo holes. With holes drilled in the sheetmetal aligned to the holes in the mobo, I'll run the stock screws down into a custom backplate. This will allow me to turn the case up onto it's normal upright position...at least in theory.
Yeah, well, isn't max temp 100C? 77C is not that far off and with extra voltage that heat goes up pretty darn quick. Also, just cranking up the volts on Core i7 is not enough...all of that other QPI/Uncore junk goes into play as well, no to mention the mass of multipliers business, etc.
I do always loosen up the timings when trying to OC to factor out the ram. Thanks for the tip though :)
Looking for more now!
Are you on air or water?
