Originally Posted by
KDC
hey guys, been following ur thread for some time now. picked up my Powercolor from ebuyer about a month ago.
i ve had no luck with overclocking, using overdrive i got clocks of 853/999. testing this with 3dmark for a number of hours with no problems. also tested it with the COD4 demo and that ran perfect too. but when i ran GRAW2 which i play alot, it crashed within seconds of running the map, happened again and again. i wiped and reinstalled everything, now overdrive constantly crashes and won't give me a clock. annoying. but the system is running well. seems i can overclock on the Crysis demo too.
i am a little worried about a problem that occurs now and then, i have my computer hooked up to my TV using the HDMi cable. certain times when after start up the screen will flicker and cut out constantly , but if i restart it the porblem seems to go away, is this the start of something bad??? should i be concerned??
ATi tool won't even load and keeps crashing on my media center XP, but i use RivaTuner instead, dunno if anyone else has that problem with it.
