Well, you got 200mhz more to go.......keep it up.
In the BIOS under the "Tools" tab their is a built in flash program, it works real well, I placed the .rom file on a usb flash drive.Quote:
Originally Posted by ken
here is the next step:
http://pichostwizard.com/img/283021.jpg
I'm having a hard time keeping the RAM ratio correct...I'm gonna need your help! :)
I think I may have screwed up royally!!! So I was chaning the BIOS and the PC just froze (in BIOS). it then rebooted by itself and I smelled something burning....:(
Now, it just keeps recycling power back and forth after 3 secs, and it wont even reach POST (nothing appears on the screen)...just recycles power!!
I tried to remove the battery and reset the BIOS jumper, but nothing...
is there a way to recover, or you guys think I blew the mobo up? could the RAM be blown???
i doubt you did anything wrong...something was defective...possibly the board, ram or VC...the board you are using now can it use the ram or VC to check them for proper operation???
if i were a betting person, i would bet that the board is fried...meaning bios chip or some small part...my foxconn board burned up on me while on the bench...the mosfet on that board burned a hole right through the middle..it was quite spectacular fire; flames and smoke!
:banana::banana::banana::banana:ty deal.Quote:
Originally Posted by ssabripo
likely a fried fet, check this thread out and let us know:Quote:
http://www.xtremesystems.org/forums/...d.php?t=112219
Has this been mentioned here previously?
http://sg.vr-zone.com/?i=4074
One DOA P5B Deluxe Wifi-AP here.
It does power up but it doesn't POST. CPU fan spins as long as the system is powered but the monitor doesn't receive a signal.
CPU (E6600), VGA (old ATi pci card / X1900XT) and RAM (TeamGroup DDDR667 D9GMH) can't really be blamed as they still work fine on the DS4.
what about the mentioned BIOS 0709 as in http://www.anandtech.com/showdoc.aspx?i=2837&p=1 ? Any1 seen it already?
Yeah...probably! I have the same symptoms!:mad:Quote:
Originally Posted by noobee
Another week of waiting while this *#&($^&*# is RMA'd :(
Feel for you guys with the problems :(
I thought i have monster problems, as PC's give me jip all the time. But so far, considering how bad I usually get it, things are going fine. and deep down I always wanted what I got this morning:
GOT AIR? - lol (I'm so happy!)
http://valid.x86-secret.com/ccpuz.php?id=125528
I've always been mighty frightened of upping northbridge voltage. well, I guess now i have a reason to be!
Congrats! I can't get mine up to 400x9, as I get failed Orthos and random restarts. I haven't tried upping all the voltages yet...What are your Vcore, Vdimm, Vfsb, Vnb and Vsb? What about memory timings?Quote:
Originally Posted by Moonraker™
Mark
yeah man...I'm interested too...it would be so helpful if you guys would post what your BIOS settings are, so that others like me can get a hint :)Quote:
Originally Posted by mhorgel
you leave it in auto??:confused:Quote:
Originally Posted by sluzbenik
what is your OC? what are your bios settings?
my board basically did something when I was changing it from teh manual 1.6v I think to auto, and before I could pres F10 to save and exit, it froze...upon reset, I smelled something and it would just start the fans for 3 secs and then reboot, continuing this cycle......burnt FET :(
Question here guys, having trouble with the Ram on a P5B Deluxe.
Cant I set the mem divider lower than 1:1? Cant underclock the mem at all?
Originally Posted by v0dka
1:1 is the lowest divider on 965 chipset
OMFG... That is stupid imo
Thanks for clearing this up, I have to go and disspoint someone now.
Quick question to the Wi-fi version users: how many of you guys actually took the wifi board out??
Not me - I actually use it.
Have u tried both DVI outputs on the videocard?Quote:
Originally Posted by largon
Overclocked a friends E6300 to FSB @ 410 today, looks like its prime stable :)
Also tried FSB @ 415 but then prime failed after 1 sek, and @ 420 it crashed in windows.
vDimm 1.95V vFSB 1.40V vCore 1.375
Will try to raise the Voltages so maby it gets stable on 420 or 425 i hope :)
Any inputs?
since you opened up your OCZ PSU, did you see any adjustable pots inside?..enquiring mind wants to know!!!:DQuote:
I did. Never even booted the system up with it in. It was the first thing I did when I got the mobo. In BIOS I also disabled firewire, floppy and the USB 9/10 (Wi/Fi)Quote:
VCore: 1.4875Quote:
VDimm: 2.1v
FSB Term: 1.4v
NB: 1.45v
SB: 1.60v
Memory is 4-4-4-12 (4GB DDR2-800mhz GeIL). They'll do so much more though with ease.
Temps are 40°c CPU and 31°c MOBO.
