How To Flash Backup BIOS?
I tried the beta F8b bios with the the AHCI rom and before Windows started loading, the BIOS said that it was updating the backup BIOS with the new one I had just flashed. Unfortunately, the computer rebooted before Windows loaded and got a BSOD the second time around. I reflashed the main BIOS to F7 final to be safe, but since there was no text saying the backup BIOS was also flashed, I assume the backup BIOS is the beta F8b BIOS that did not work for me.
My question is this: is there a way to manually flash the backup BIOS to the F7 final BIOS so that if something happens, the computer will not try to load a backup BIOS that does not work?
AHCI: Drives Not Detected...
My computer was working fine with an SSD and SATA HDs on the ICH10 and optical drives on the SATA2 controllers using AHCI for both ICH10 and the SATA2 controllers. I wanted to install Windows 7, and during the first go around, I messed up a driver install within the OS, so I went to reinstall it. When I rebooted again, the computer froze under the ACHI drive detect screen in the BIOS. None of the drives were ever detected. I then went back to IDE all around and used another HD that had a Vista install. It booted up fine.
My problem is I have changed nothing hardware related. I have tried to clear the CMOS, reinstall the F7 Final BIOS, and update the BIOS to F8b. I cannot get AHCI to detect any of my drives, but IDE mode works fine on another HD. AHCI was working FINE the way I wanted before. All I wanted to do was reboot and reinstall Windows 7. What I am saying is: all the hardware works. It has before in AHCI and works now in IDE. Any suggestions?
BIOS Settings (What I am attempting):
- All clocks auto or presets from a clean BIOS install
- ACHI for both ICH10 and SATA2 controllers
- SATA native mode enabled
- Intel SSD as drive to load OS on
- Any wake features disabled
- No floppy detect
- Power saving features not changed
