Lookin good Serg!
No problem radaja, always a pleasure to help a fellow OCer out.
Got my kit today too, nothing to put them in, but they look nice, lol.
Lookin good Serg!
Yep looks promising Sergio congrats!
Thanks Elano (btw theres a player with your name on BRZ team :D)
This mem behave fantastic on 1600 PL7 i only had 2 !!! "not convergent on SQR" lol pushing timmings on stock volts
weird thing is i cant boot them at 2000, but gskills at 2000 1T 8-9-8-24 PL8 gave me less bndw than this at 1600 6-6-5-18 PL7 2T lol
either way very happy i will try for 4750 (x9,5) or 4608 (x9) stable now :)
Cheers my friend :up:
Good luck for Brazil :up:
Sergio
You should be able to get the timings even tighter than that, something like 6-6-4-16-52. :up:
I'm looking at picking up one of these boards andressergio, can you confirm that all the RAM dividers work on it? And can you boot at 1:2 500FSB with the RAM at CL8?
And also whats the max 32M stable FSB you can get out of your quad. You can try lowering to 6x multi if you want.
I think lower-mid 1.7s is generally considered safe for 24/7 but not 100% sure. For 24/7 use I never really needed to raise vdimm above stock, but I only primed this setup to 506*9 1620 6-6-4-16-52, I always ran mine at 1.66 bios which is like 1.63v.
yes i checked when you posted here
http://www.xtremesystems.org/forums/...05132&page=213
you are runing PL8, im on PL7 and you needed 1,7 set on bios wich idles at 1,66
Thanks for the tips hypers are like old good D9 as zsams said :D
That was the baseline run for this setup to get a workable template, all runs after used 1.66 bios. :up: With F8c PL8 is the lowest it will let me drop but PL wont affect vdimm.
http://www.xtremesystems.org/forums/...postcount=5542
Still on stock vdimm pushing and testing what are the best timmings, so far loving this ones
X3380@ 4500
ST 2200 CL8@ 1600 6-6-5-18 trfc 52 Performace Level 7 - Vdimm 1,65
http://img194.imageshack.us/img194/2...cr2pl7trfc.png
http://img197.imageshack.us/img197/6373/captura1r.png
http://img341.imageshack.us/img341/2...cr2pl7trfc.png
cheers :toast:
Sergio
Hi guys i have a couple of question´s
Iam looking for a chipset cooler for ep45-ud3p , iam using a thermalright ultra extreme and the 1st pci-e 1x is being used by my xonar stx , so in your opinion is there any cooler that can fit in?
Other thing is , if i place the sound card in the pcie 16x orange the first one will work @ 8x like it did when you used 2 gpus?
Thz in advance.:up:
1.52 for 500 fsb it´s that safe for 24/7?
Iam struggling to get the chipset stable , iam using @ 500 fsb @ 1.38 and using 900,900,0,50? any suggestion on that aspect?
Anyone else on the EP45T-UD3P not able to adjust memory timings with memset?
So annoying having to keep going back to the bios to tighten timings after achieving a good overclock.
thanks mate after 20 years we are back hope we end on the finals :D
you must use version 4.1
you can find all latest programs here ;)
http://forums.tweaktown.com/f69/late...y-tools-30530/
give a shot it will work :up:
Andresergio can you give me some tips?
I need some settings for a 8400 @ 4500 , 500 fsb 2.4 memory multiplier.
Iam runing ocz reapers @ 1200 @ 5-5-5-15 pl 8 2.3 v
For a Dual core how can obtain the best values for vtt cpu and mch ref ?
I need cpu termination voltage , cpu refrence , and mch reference .
Has i said in advanced settings iam using 900, 900 , 0 ,50 , but iam going crazy because its orthos stable and now in BC2 i get CTD sometimes the sound loops and i get a blue screen and it reboots iam losing all the hope...
All i want its my rig stable at least to play some hours of bad company 2 without problems.
Having to change settings almost everyday is a BIT#H!
that are some impressive numbers andre i have a lot less :(
