Hans how are you
till release of EP45 USB3P this reboot loop is known, but not on low FSB speeds, in my case was above 500 fsb on the UD3P...now they fixed a lot of it you have to real make crap to make it reboot loop
Cheers :toast:
Sergio
[OFF]
My Asus P5E X38 flashed to Asus Rampage Formula X48 has no problems with quad@500fsb and 2x2 DDR2 1200MHz with 1.72 on nb.
LinX
http://img99.imageshack.us/img99/557...xstable.th.jpg
Prime95 Blend
http://img718.imageshack.us/img718/8...dstable.th.jpg
[/OFF]
Impressive for an Asus - good work. Shame it's taking so much vcore though - good job your temps are under control - must be some serious cooling or that chip loves volts!
@sergio:
MIIF - did I say that? It's almost like swearing now! I need to sell that thing and go on holiday with the money!
So I decided to look at newer BIOS's for the GA-EP45T-UD3LR since I was running F6b from Nov/2009. :D Wow, now there was F7, F8, F9 and F10. So I thought let's do F10....WRONG! :mad: Did not like settings I was using under F6b at all. Do then tried F9...same thing :mad: No matter what I tweaked under F9 or F10 could not boot without BIOS reverting to failsafe settings. Luckily when I tried F8 there were no issues at all. Scared me for a while there and thought I boinked my system :eek:.
Just another experience to give me more grey hairs!:rofl: Oh well, back to work.
Intresting read ...
Iam wondering what bioses are you all using for ep45-ud3p, i would aprecciate some feedback´s and if someone knows any major improvement over the f4 in performance or stability let me know :yepp:
I use F4, because it gives me not so many troubles.:up:
Having read Void Warranty's suggestion, I decided to try it on my board. Prior (was still getting used to the forum layout and neglected to have Hybrid enabled), I mentioned that I couldn't reach stability at 444. After setting the latch to 333, as I was already on 2.00B, stability was obtained. 450 passed super-pi once, then errored out between the 13th and 23rd iteration thereafter. 445, once the Advanced Timing Control were reset to Auto, proved stable at Standard and Turbo for 32M SuperPi and 4096 custom Orthos runs.
http://img37.imageshack.us/img37/838...45start.th.jpg http://img18.imageshack.us/img18/184...5middle.th.jpg http://img718.imageshack.us/img718/9...o445end.th.jpg http://img715.imageshack.us/img715/2...everest.th.jpg
445 Bios template:
With my memory, this is about as far as I can go. Ambient is 28, RH of 30 (outside, the heat index was around 37 with RH of 60). CPU cooler used is Masscool's 8WA741.Code:Motherboard: Model: EP45-UD3L Rev#: 1.1 Bios Version: F9
Cpu: E7400 266 x 10.5 0.85v-1.3625v
Ram: Gskill, F2-6400CL5D-4GBPQ, http://www.gskill.com/products.php?index=46
Power Supply Unit: PCPower, Silencer 500W, Single Rail @ 35A, 80+Bronze
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster -------------- : [Auto]
CPU Clock Ratio ---------------------- : [8]
Fine CPU Clock Ratio ----------------- : [0.5]
CPU Frequency ---------------------: 3.783GHz (445 x 8.5)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control --------------- : [Enabled]
CPU Host Frequency (Mhz) --------------: [445]
PCI Express Frequency (Mhz) ---------- : [100]
C.I.A.2 ------------------------------ : [Disabled]
Advanced Clock Control
CPU Clock Drive ---------------------- : [900]
PCI Express Clock Drive -------------- : [900]
CPU Clock Skew (ps) ------------------ : [100]
MCH Clock Skew (ps) ------------------ : [50]
DRAM Performance Control
Performance Enhance ------------------- : [Turbo]
(G)MCH Frequency Latch ---------------- : [333]
System Memory Multiplier -------------- : [2.00B]
Memory Frequency (Mhz) ---------------- : [890]
DRAM Timing Selectable ---------------- : [Manual]
Standard Timing Control
CAS Latency Time -------- 5 ---------- : [5]
tRCD ------------------- 5 ---------- : [5]
tRP --------------------- 5 ---------- : [5]
tRAS ------------------- 15 ---------- : [15]
tRRD ------------------- 3 ---------- : [Auto]
tWTR ------------------- 3 ---------- : [Auto]
tWR --------------------- 6 ---------- : [Auto]
tRFC ------------------- 52 ---------- : [Auto]
tRTP ------------------- 3 ---------- : [Auto]
Command Rate (CMD) -------------------- : [Auto]
Channel A
Static tRead Value --------------------- : [10]
tRD Phase0 Adjustment ------------------ : [Auto]
tRD Phase1 Adjustment ------------------ : [Auto]
tRD Phase2 Adjustment ------------------ : [Auto]
tRD Phase3 Adjustment ------------------ : [Auto]
Trd2rd(Different Rank) ----------------- : [Auto]
Twr2wr(Different Rank) ----------------- : [Auto]
Twr2rd(Different Rank) ----------------- : [Auto]
Trd2wr(Same/Diff Rank) ----------------- : [Auto]
Dimm1 Clock Skew Control --------------- : [Auto] ps
Dimm2 Clock Skew Control --------------- : [Auto] ps
Channel B
Motherboard Voltage Control
CPU
Voltage Types------------ Normal -------- Current -----
Load-Line Calibration ----------------- : [Enabled]
CPU Vcore --------------- 1.2875 ---- : [1.3625]
CPU Termination --------- 1.200V ----- : [1.24]
CPU PLL ----------------- 1.550V ----- : [1.55]
CPU Reference ----------- 0.805V ----- : [0.787] 0.76 ET6
MCH/ICH
MCH Core ---------------- 1.100V ------- : [1.32]
MCH Reference ----------- 0.760V ------- : [0.785] 0.76 ET6
ICH I/O ----------------- 1.55V ------- : [1.55]
ICH Core ---------------- 1.10V ------- : [1.10]
DRAM
DRAM Voltage ------------ 1.80V ------- : [1.90]
The Workhorse
tomorrow i think i will play with the rex, build the BenchZoner XP load....
http://img.techpowerup.org/100617/giginaction.jpg
Yeaah ,its good to be back and benching. I've got a 240 BIX dumped in a bucket of ice and it's doing me wonders. Idling at 12c with 1.65v.
My latest and greatest result:
Will be pushing further.
systemviper,sweet picture
jjjc_93,awesome OC on your X3360:up:
hey anyone want to trade thier Q9650's for my P55A-UD7?
I figured id post this for anyone considering to go cold, the Koolance V2 pot has a bit of a clearance issue with the center two caps at the top of out boards.
http://i131.photobucket.com/albums/p...000_0069-2.jpg
I was bored today at work and screwed with my E7500 Work Setup in my sig. Not stable, but oh well it was fun and passed some time to get to quiting time!:D
http://img9.imageshack.us/img9/9413/e75008x525.jpg
Now I need to get cracking on my E8500 Home Setup and shoot for 8 or 8.5 x 500-525 FSB!
This is gonna be fun, i got a few runs that i haven't posted with the x3360, plus i think i will try it in the rex this weekend, i think this must happen.... :yepp:
edit,: maybe i will just throw it back in the gig and try that Team 1300 that i just picked up, hmmmmmm
I got that board when they first came out, even before it was a proven overclocker, and it has been rockin ever since :surf:
