I've got myself a 165, CCB1E 0605 XPMW, just waiting on my power supply to turn up and i'll be giving her a work out soon, god i wish this PSU would hurry up, oh yeah and the batch number is 0008 :banana:
My 0610 is prime stable for 10 hours + with small FFT's
http://img220.imageshack.us/img220/2...475vinb.th.jpg
But i cant get get it go an hour on large FFT's, I thought it may be my RAM so I tested with my spare OCZ 4200EL but the same result. :(
yea, i wish the chip screwed up and set its multi to 16, instead of the software screwing up and just displaying the wrong multi. a 165 with a 16x multi would be neat.Quote:
Originally Posted by HiJon89
Just got my 165 opty from monarch, it is a CCB1E 0609FPMW. :oscar: perhaps?
Now, just have to wait for my heatsink to come...:dammit:
nice, they are pumping out the good steppings like crazy :clap:Quote:
Originally Posted by Kobaltrock
Originally Posted by Mastactor
TY :)
I am going to probally be retesting the chip again once I get watercooling.
My main goal right now is to get 268 stable on the memory, but I don't think its going to happen.
Got my CCB1E 0609FPMW from monarch. It's good, but not nearly as good as I hoped.. so far 2.74 has failed on stock voltage, 2.7 is going ok. Keep in mind it's about 80-85F out today, that could have something to do with it
2 Other steppings to avoid.
0534MPMW.. The first Opty 170 I owned. Wouldnt do 2.5
0546SPMW.. My Second 170 2.6 Needed 1.5 2.65-2.7 Needs 1.55
Originally Posted by Repoman
Why did you get another chip repo? That CC1BE you have now is awsome.
That 0609 seems to be performing worse that the 0610.
New Ultra-D -> SLI-D installed, thanks Plywood99!
2850 on stock voltage right now, prime stable thus far (Reported 1.31v by smart gaurdian)
nice. 3000 @ 1.45 would be nice to see :)Quote:
Originally Posted by CompGeek
It's fun to test them, then if it's good I can make a quick buck off of it. I know I saw one good 0609 that had 2.96@1.4v, so they're not all that bad.Quote:
Originally Posted by Spazilton
BTW 0534 on 170 is bad, on 165 it was great for the time. I had one at 2.7@1.45v
Im now tryin 2950 @ 1.4v reported (1.45 actual)
Do you have a DMM compgeek? You can measure your actual vcore with it.. plus I'm curious to see how far it overvolts :p: Some people say there's only does an extra .01v under load, mine does .04
No I dont. Heres a ss:
1.45v set in BIOS, dual priming
http://img434.imageshack.us/img434/1945/cpu29495co.png
Thus far Im only 50mhz behind absolute0's CCB1E 0608MPMW, it did 3ghz @ 1.4v reported.
OK, 3072mhz @ 1.52 reported (1.55 set), we'll see how this goes.
EDIT: Meh, minute and a half. 3050 should be stable though.
should have a CCBBE0610DPMW waiting at home for me
3065/1.53 looks like my new 24/7...
DUDE! stop that prime now!!!!!!!!!!!!!!Quote:
Originally Posted by famich
did you not even notice it's not laoding your cpu???
it's just paging a huge file and thrashing your HDD's!!
DONT RUN BLEND IF IT SAYS PAGING!!!
yea dude, that will destroy your HDDs. i started a thread about that, we started working with john on that issue. although i believe its OS related, not prime related
Follows the .1v/100MHz rule exactlyQuote:
If my 0608 would do that, I'd have 3.2Ghz@1.6v :(
well in am now waiting for my opty to get here. I didnt make the cut off and fedex doesnt deliver on sat or sunday so i have to wait intill monday :( Was thinking of getting an "artic freezer 64 pro" for now. whats a good watercooling system or do you have to buy all the parts seperate for better results?
all parts seperate is my suggestion.
