Just in case you haven't been following....
Glad to see this place back up!
http://www.dfi-street.com/forum/show...&threadid=1490 :YIPPIE: :cussing: :bsod: :lol: :brick: :bounces:
Well, I have mine up and running, BUT
so far, nothing but problems if I change anything in the bios that has to do with CPU/RAM settings.
So far all I can successfully do is disable the Full Logo Screen, change the boot sequence, make AGP the first read, that is about it.
Everytime I try to save and reboot, with the exception of the above mentioned stuffs, the system needs to have the CMOS cleared and I have to do it all over again.
Also, the darn CPU is running @69*C, stock cooler w/AS Ceramic, and at stock voltages all around.
This is not starting out to be a happy camper experience so far.
I am going to get another aftermarket CPU cooler, prolly a 948U, but until then, I am laying low.
Any tips or comments welcome.
baldy
disregard sig for now. :upset:
okay, got the beta installed and
i am running @ 8x250 so far. thanks for the linkee. i was turning off CPU throttling, i suppose that is why it hung at rebootage. learning quickly..............
nice choices on the Vdimm, my 3.3 line is @3.5 right now, maybe i will pump it up some more with the pots so i can throw some volts at the bh-5.
anyway, got the single stick in slot one. what settings are necessary to run both sticks of BH-5 for the gig????
anywho, thanks again for the info :YIPPIE: and link for the beta bios info. temps did drop dramatically, but still seem somewhat high. once it is sorted, the prommie will come back online.
baldy :YIPPIE:
