I do agree that in the cpu market, AMD is not doing great against Intel but in the gfx market, AMD (ATi) is competing pretty well against nvidia and there are lots of pre-built systems or laptops with ATi cards.
I should add I want idle power usage from my graphics cards. I could care less about load but some of the Nvidia cards have insane idle usage. If they made a GTX 580 dual gpu card I would be interested. Sadly Nvidia releasing a real Fermi card a year after they promised it kinda of pisses me off.
6950 is 1536sp @ 890 Mhz apparently.
1gb vram
Not to mention he's either high or insane...
Sincerely, part of me hopes you're right regarding this, GTX 580 rocks & priced sensibly @US$ 549 at most (i'm quite confident it will, with the leaked info that i've got about it), and HD 6970 is somewhat inferior and costs @US$ 449 at most, fulfilling my pricing expectation & nullifying yours. Therefore, i don't have to part ways with this forum posting wise for the next 6 months. ;) :D
OTOH, the other part of me is willing to take the punishment, as long we get another R300 coming our way. I'm just torn inside. :ROTF:
Forrest@B3D. Not sure if he's messing around or not.
Originally Posted by Forrest
4 Rasterizers with 2 tessellator unis.
2 Rasterizer with a Tessellation Unit per Ultra-Threaded Dispatch Processor (UTDP) and each UTDP has 12 SIMDs.
What do you think ??
He's most certainly not. Only thing is that he might have the cards factory disabled by AMD with usual pre-launch crippled BIOS but I doubt that's the case so close to launch.
You should remember his post from last year and first pics of Juniper he posted on B3D.
http://forum.beyond3d.com/showthread...65#post1341265
http://forum.beyond3d.com/showpost.p...postcount=3994
The card has 8 plus 6 pin power (which makes 300W) so I think it'll be around 250W, which is consistent with what we have heard until now.
If AMD has managed to keep performance/watt the same as 6800 (5770's perf/watt is around the same as 5870's, for example), we could be looking at a card that's 65% faster than HD6870, which would make it:
- 50-55 percent faster than HD5870.
- 15 percent faster than HD5970.
- 12-14 percent faster than the GTX 580 which according to rumors should be around 15 to 20 percent faster than GTX 480.
Also we must consider that a new core configuration will have a variable improvement in various applications. Real world code typically lets a 5th shader idle in evergreen. But benchmarks and tuned code can utilize the 5th shader more effectively. So we may have a situation where synthetic tests don't show as much of an improvement in cayman as in real world tests. A different % performance improvement depending on how effectively code utilized the old architecture.
While i don't think the situation will be that simple & your numbers are correct (i don't think AMD will make their own version of baconator), i do think your thought brought another interesting question.
Will AMD improve their performance/watt in this mArch ? Stay the same ? or regress ? Because it seems nVidia has succesfully increased their efficiency in this metric, no matter how small it might be perceived. :shrug:
Well, to be fair, nVidia's predecessor product wasn't exactly an efficient built in the first place, it would be much easier going from horrible to acceptable than improving on a quite efficient design like Cypress boards. :yepp:
* 2.15 billion 40nm transistors
* TeraScale 2 Unified Processing Architecture
o 1600 Stream Processing Units
o 80 Texture Units
o 128 Z/Stencil ROP Units
o 32 Color ROP Units
* GDDR5 interface with 153.6 GB/sec of memory bandwidth
* Engine clock speed: 850 MHz
* Maximum board power: 188 Watt
so better shader utilisation ... with about the same amount of shaders should give us a good enough boost :D
... please amd give us antilles allready
I do not thin such info is worth dedicatinga thread, so here
http://news.softpedia.com/news/AMD-S...t-164938.shtml
